Cineform connect HD vs Raylight for HVX200
What are the advantages/disadvantages of each, and which one would you recommend?
(I know this topic has been pounded to death, but I want some more opinions.) Thanks. |
no recompression or zero loss of quality on cuts. In other words the data contained in each frame (as recorded by the camera) is left untouched during the editing process. I would recommend it for anyone might be doing a transfer to film, or digital projection, since it will deliver the highest quality image possible to the transfer process. |
The main advantage of CineForm is it is NOT NATIVE, therefore you aren't limit by DVCPRO_HD's lower 960x720 resolution, you are free to do post elements like color correction, transitions and titles, without the multi-generation losses that native codecs suffer (CineForm vs DVCPRO-HD -- http://www.cineform.com/technology/H...lysis10bit.htm.) Mario has said on other posts that native for film out is best to do cuts only and then employ the film-out house to do the color correction and titles (and I guess transitions also.) In this he is correct -- mathematically, but the benefits of this work-flow are nil as it shows no visual difference if you did cuts only CineForm. He is correct that users can make mistakes, making it more difficult for film-out, yet converting to CineForm does not change the dynamic range of the image, preserving all the original data. I would think if you planned to pay a film out house to go all you post work you wouldn't be considering either CineForm Connect HD or RayLight.
So to answer the question (which I was hoping would be answered by non-corporate players). CineForm's advantage is flexibility, higher quality in typical multi-generation post, higher performance, flexibility in resolution, flexibility in bit-rate, simpler file handing (one AVI file per clip vs AVI + many MXFs), flexibility to cut HDV and P2 media together in the same codec. Remember both products are free to try. |
I use both Raylight and Cineform.
I'm pretty fond of the Cineform codec. It's useful to have a higher resolution playback for clients and it seems to speed up editing for me. When editing with Raylight I normally switch between the different resolution settings and that adds a bit of time when you're in the NLE no matter what you do. It is usefull not needing to worry about all the MXF files too. |
