Multi bracket for H4N, mic, etc?
Hi,
I have a a Sony NEX7 and I´d like to find some sort of multi bracket so that I can use a mic, a zoom H4N and maybe a third accessory. But I don´t want all of this weight to be over the NEX7. I want it to hook up to the tripod so that I can place the NEX7 over it, as well as the other accessories. Sorry for my ignorance, but is there such a thing? Since, I live in Brazil I have to buy from ebay. I was thinking about something like this Do you think it would put too much stress on the NEX7's hot shoe? I´ve also seen these 2 options but I find them too bulky and I´m not sure you can mount them directly into a tripod http://www.ebay.com/itm/ALZO-Transfo...-/390360254927 http://www.ebay.com/itm/Handheld-Tri...item5198fa7504 cheers Rafa |
Re: Multi bracket for H4N, mic, etc?
I use this:
I attach a zoom H4N and a microphone on it, works well. |
I highly recommend the Gearbox by Photography and Cinema. I picked up mine with the rod adaptor kit.
GearBox GB-1 - Video Accessory Cage by PNC | Photography and Cinema - Store |
You can mount a manfrotto (or other) quick-release plate to the bottom of the rod kit they sell for it. However, it doesn't have a guide pin hole, so it may torque a bit with use. I just ordered an additional tripod rod adaptor, which will mean I use the P&C kit to mount to rods, then have another rod-based mount that is a lot more robust to mount to the tripod. But, yes, you can certainly do it with the kit as provided.
Thanks for the tip, Ryan. I currently use a $9 Adorama C bracket (pictured below) - but I just put the
in my cart at Amazon. It is tough to beat a $94 price for a high quality camera cage!
Cheers, Bill https://lh4.googleusercontent.com/-H...4/IMG_0700.JPG |
