FS-CONUS: Zacuto Half Cage - $285 at DVinfo.net
Old January 25th, 2016, 02:36 PM   #1
The Zacuto Half Cage creates a solid, adjustable, universal cage structure around the side and top of your camera rig. This will be the last cage you need to buy! It is adjustable to work with all cameras, sizes and shapes. It creates great stability, especially when shooting with DSLR's, giving your camera a sturdy side grip and the ability to add a top grip. The Half Cage is rod mounted so it works independently of your actual baseplate allowing you to adjust its position. It can be positioned and locked via an Allen onto 15mm lightweight rods. The Half Cage features a special magnetic indentation along the side for storing the included Allen key.
The side handle and most of the cheese plate holes are set to work on the right hand side of the camera but can be reversed if a left hand cage grip is desired for 2 handed operation. The Half Cage can mount just in front of your baseplate over the lens or behind your camera on rear rods depending on the balance point of your rig and where you want to add accessories.
Text: 941-276-2390
Zacuto Half Cage
Mac Charalambous is offline   Reply
Adorama
(800) 223-2500
New York, NY
New York, NY
Texas Media Systems
(512) 440-1400
Austin, TX
Precision Camera
(800) 677-1023
Austin, TX
VideoGuys
(800) 323-2325
Mineola, NY
1998-2018 The Digital Video Information Network
