-   Remote Lens Controllers (https://www.dvinfo.net/forum/remote-lens-controllers/)
-   -   LANC remote issue (https://www.dvinfo.net/forum/remote-lens-controllers/32347-lanc-remote-issue.html)
Raul Dudnic September 22nd, 2004 09:21 AM
LANC remote issue
Hello
Please advise or point me to the thread:
I purchased a zoom controller
http://www.signvideo.com/zoom-commander-digital-zoom-controller_II_pro.htm
that should be connected through LANC. I couln't make it work. Before buying it I was assured by the vendor that it works with PDX 10. Before this one I purchased six months ago another one, a cheaper one which didn't work either. I thought that it was due to the poor quality of the item.
I couldn't find in the camera menu anything about setting up the LANC, neither in the manual.
Thank you in advance,
Raul
Chris Hour October 7th, 2004 07:45 PM
Hi Paul,
I bought a Lanc controller for my PD-100 from sign video as well.
I pleased to say that mine works fine.
My advice, find a friend with a “consumer” Sony video cam and try it in theirs or go to your local Sony dealer and try it in one of their Camera’s.
I should work in any Sony cam with a LANC.
If it works in the other cameras you may have a loose connection. (Hopefully an easy fix).
If it doesn’t work contact Sign Video. I’m sure they’ll replace it.
Once you use a Lanc controller on a tripod or boom youreally appreciate the investment.
Cheers
Chris in Hamilton, On, Canada
Boyd Ostroff October 7th, 2004 09:14 PM
I don't think there are any menus that need configuring with LANC, it should work right out of the box. No experience with this controller, but my Varizoom Pro-L has always worked perfectly on my PDX10. I agree with Chris, find another camera to try it on.
I know this is a dumb question, but you are sure that you've plugged it into the correct jack, right? I don't think the PDX-10 requires any special "flavor" of LANC. Hopefully it's a defect in your controller and not your camera.
Raul Dudnic October 10th, 2004 09:18 AM
Thanks Chris, thanks Boyd
It is actually the camera that has the problem. I tested the zoom controller on another PDX 10 and works fine. This is a factory defect, LANC was never used before.
Thank you again
Sean McHenry October 12th, 2004 02:07 PM
Does this unit have progressive zoom rates? That is, are the zoom buttons pressure sensetive?
I am looking for a small zoom controller that is progressive.
Sean McHenry
Raul Dudnic October 12th, 2004 04:28 PM
No, they are not touch-sensitive like the zoom button on the PDX-10; the controller that I bought has variable speeds. Have a look:
Sean McHenry October 13th, 2004 08:45 PM
Thatnks for the reply. Yep. Took a look at it. Looks interesting but I may go for the VariZoom LX. It has a sort of rocker on it that is variable as well as some nice extra controlls.
I have to get something with a smooth takeoff and variable rate.
Sean McHenry
