Control three DV camcorders at once...
As if you didn't have enough to do already, apparently you can now control three cams at once...
http://www.grizzlypro.com/index.htm Thoughts, comments, feedback? Looks interesting to me. |
Now if it was wireless, THAT would be cool. But with cams having to be wired, it must limit usefulness and require its own crew to run/gaff cables.. OTOH, Dave Williams is a bright and innovative guy and HE likes it...
Wireless Remote
I took the tack of making the video feed, camera control and pan/tilt control interface a single cat5 cable (way smaller than any other remote camera on the market) which makes setup and takedown significantly easier. No crew needed :-) What you can do is hire a totally unskilled assistant to lug all of your stuff and help with cables. No longer need to get someone who can keep the camera in focus, not zoom in and out all the time, keep the camera running etc etc.. I've heard folks talk about how they put together a home brew system with the pyramid or something but invariably it ends up that they are only running it for 20 or 30 feet or they quietly stop talking about the system when it fails them at an important shoot. |
Speaking of controls, I just had an idea. I used an IR repeater on my home theater stuff about a year ago so I could relocate all the gear to the basement. Ran the wiring through the walls from the basement.
These things are available from Best Buy. Here's what it does. You set up a small egg shaped transmitter anywhere you want in the room you want to be in when controlling the gear. You put the receiving unit where the gear is. The transmitter sees the IR from your various remotes and sends RF, not IR, to the receiver which turns the signal back into IR and blasts it out in a wide arc pattern. Get the idea? OK, what if you bought 2 or 3 or more of these things, used one transmitter but used several receivers near each camera? Ah ha... Multiple IR control for cameras in different locations. There is no training these like universal remotes because they sinply rebroadcast what you send them. Interesting idea? Sean McHenry |
Phil,
I would like to ask about the exposure control of your product, how it works, can it independently control iris? We have a problem with the new Sony consumer HDV camera. the HC1 (and probably many consumer cameras). The only manual exposure control is a combined combination of shutter, iris, and gain control, of these we can only lock down one, meaning manual exposure control still adjusts the other two. Most knowledgeable people here want to control all independently (at least the Iris for depth of field). Can your device control iris independently, or gain or shutter? I have thought of making a Firewire/Lanc handle controller myself to control these things. But for $100 a control device like this might be up your alley. |
Phil,
I agree with you, wireless has it's problem. There is technology with a range of more than 20-30 feet. It is possible to setup over hundreds of feet, or miles. Some buffering, digital and reconstructive coding are needed though for reliability, and set antennas up with clear line of site of each other. However modern wireless network standards will do most of this in future. With newer technology and standards you shortly could see 100's of megabits over long distances (vs 108Mb's per device (upto 54Mb's real throughput) over hundreds of feet). Thanks Wayne. |
I think you are correct that there are some better solutions coming, particularly in the area of home video networking. Unfortunately, most homes are not more than 100 feet in any direction and so the development is targetted at that range. When I can figure out how to do a solution that: 1) Is affordable. 2) Is reliable 3) Doesn't require 30 pounds of batteries or an AC connection 4) Can carry the video feed, camera control and pantilt control on the same channel I'll add it. I think that there is a perception that some type of star trek communication can be done when, in fact, someone buying something built on a simple ISM band radio would be significantly disappointed. A couple of manufacturers of pantilt heads sell a wireless option but it only controls the movement of the pantilt (what good is that?), they leave the rest of the solution up to the user. Even at that they cost over $600/head. |
How about something that can just set the camera to record/standby. Doing a hunting 2 camera shoot and would like to turn on/off the Broll camera from 200 feet max. Is there anything out there?
Jim |
If the cameras in question can handle IR, see my previous post.
Sean McHenry |
And where would I find a plug 5 miles in the middle of nowhere?
Extension cable...
Phill,
Yes, wireless is not needed if the application is permanently fixed, and enough people running their own wireless equipment (even bluetooth) on the same band could stuff things up too. If you ever are interested in a portable/transportable version. The wireless network technology is pretty cutting edge even in price, and designed to work in offices and across distance from 100 feet to 1000+ feet (if you get the right one) on reasonably small antennas. Cheap IR can be made to operate at 1000 feet. Batteries, probably the newer version of the Lithium technology, to be introduced next year (I think) with 10K recharge cycles. Nothings as cheap to produce what you already, but for a different product would be good. Thanks |
My belief is that this a fairly cost sensitive application and so I've spent most of my energy there. The motion control portion of the system is, for the most part, as good as some of the $15,000 solutions. You can move the camera at a distance just like you were on a fluid head tripod ... it's pretty cool! I'm very interested in developing a wireless solution, but I'm also dedicated to the principle that my customers have to be happy with the system that I sell them and I don't think I can do that with wireless yet. The single cat5 cable solution is really much easier to work with than you might think, and it is cheaper and more reliable. Virtually all of my current customers use it as a portable solution. If you've got a specific technology solution that might work I'd love to look at it. So far the best possibility I've seen is this one: www.air5.com. Regards, Phil phil@grizzlypro.com |
Any small device, like those IR/RF devices, can be run by battery. I can't recall but I think they were small 9v AC supplies meaning at most, stack 2 9v batteries and off you go.
I'm used to adapting and building what I need. Easy stuff for me but if you want some expensive, off the shelf "thing" specifically for such a project, you may be waiting a long time. Sean McHenry |
