which cable to use lcd dvi-d at DVinfo.net
Old November 18th, 2007, 08:05 PM   #1
I just bought a LG lcd 20.1'' monitor in which has a dvi-d connection. My graphics card has a dvi-i connector. Can someone tell me or direct me to the correct cable for this set-up. Thanks
richard tamayo
Richard Tamayo is offline   Reply With Quote
Old November 18th, 2007, 08:07 PM   #2
It should be a normal DVI cable.
DVI-I I believe (might be wrong here) that the video card can either output a DVI or VGA signal. If you stick a normal DVI-VGA adapter there, you can have that port send out a VGA signal.
DVI-D ports only do DVI out. Not both like DVI-I.
Glenn Chan is offline   Reply
