Advice on JVC Monitor at DVinfo.net
Old November 4th, 2008, 09:57 AM   #1
I'm in the process of upgrading various bits of kit and have been looking at this JVC 15'' monitor TM-HI50CG. I'm only doing SD no HD with the Canon xl2 FCE HD,iMac 2GHz Intel Core Duo
I presume this monitor will be ok, I know I will also need some form of AD conversion so I'm also looking at the Canopus ADVC110.
The JVC monitor has a slot for an extra SDI slot/ I'm not sure about this or its use/ do I need it.
If I were to use the JVC how would I then monitor the audio?, through the speaker in the iMac.
Any thoughts and opinions on this or better would be appreciated.
Steve
Steve Shirvington is offline   Reply With Quote
Old November 4th, 2008, 10:00 AM   #2
Went looking for the monitor in question and came up with no results in Google. Do you have the model number correct?
Old November 4th, 2008, 10:11 AM   #3
JVC Monitor
Heres where I found it, JVC Video Output Monitors including the JVC DT-V100CG 10" High Definition Monitor, the DT-V17L3D 17" LCD Portable HD Monitor and the DT-V9L1D 9" LCD Portable HD Monitor
Hope this helps
steve
Old November 4th, 2008, 10:25 AM   #4
I have that same monitor and have found it to be very reliable and color accurate with a little calibration. I also use the ADS Pyro converter and have found it to be a lower cost alternative to the canopus. As far as the audio goes, you will need to run an audio cable from the converter to your speakers. This will ensure you audio and video matches.
Brian Tori is offline   Reply With Quote
Old November 4th, 2008, 11:17 AM   #5
Thanks for the advice Brian
Old November 4th, 2008, 12:47 PM   #6
Also, be aware that the CRT only resolves 230 TV lines in HD 16:9 mode, according to the Spec Sheet on the link you posted.
