Datacolour Spyder3 Pro or TV ? at DVinfo.net
Old March 19th, 2009, 01:02 PM   #1
I'm just wondering which product to purchase as I cannot afford to buy much at the moment, so it's one or the other for the time being.
I thought if I bought the Spyder3 TV, that I could still calibrate my computer monitors as well ?
I do HD editing, and the videos are for TV as well as the internet so I need some kind of calibration happening as I'm just guessing at the moment.
Cheers for any help !
Rob O'Day is offline   Reply With Quote
Old March 20th, 2009, 08:05 AM   #2
Why not just run bars into your production monitor and do a proper setup?
That will save you the expense of buying something you don't need.
Old March 20th, 2009, 08:13 AM   #3
David,
putting bars on the screen is easy, but what would be the procedure for setting from them?
DATS ALL FOLKS
Dale W. Guthormsen
Old March 21st, 2009, 03:23 PM   #4
Here is a link... - Color Bars
Old March 23rd, 2009, 03:59 PM   #5
It's the brightness/contrast I have problems with, looks fine on my PC monitor but very bright on the TV.
Old March 18th, 2010, 05:11 PM   #6
That's right
It's going to look different on a computer monitor and a television. Especially a CRT to a flat screen. The way these devices handle color and brightness is different. Most people use a reference monitor alongside their computer monitor and adjust color and brightness according to that. You can calibrate your computer monitor but you're not going to have accurate color still because it does not display the same as a CRT. You can use an LCD reference monitor, but they cost quite a lot. If you don't have a monitor, use a vectorscope and a waveform monitor to help you.
Jonathan Heppner is offline   Reply With Quote
Old March 18th, 2010, 05:15 PM   #7
spyder 3 pro
If you have a spyder 3 pro you can buy software to use it on your tv. It is the same device, it just has different software between the tv, pro and elite.
Last edited by Jonathan Heppner; March 18th, 2010 at 06:06 PM. Reason: I looked into it
