confused on power? at DVinfo.net
Old June 9th, 2009, 03:59 PM   #1
confused on power?
Grreeting all,
As the title says I have a slight power problem not sure exactly
how im going to hook this 7" lcd I got off ebay to my anton buaer battery.
here is a few pics can someone guide me through how to do this? so I dont
burn up my lcd. I understand the red and black wires but what is the deal
with the male mini is this power also?
Thanks all
Shawn
Shawn Kessler is offline   Reply With Quote
Old June 9th, 2009, 09:28 PM   #2
I'm not sure I understand your questions about the male mini. Is it the only connector for the power or are there separate leads also? One thing I would be careful of is I believe AB batteries put out 14.4 V that's more than the 12 V the LCD wants. Unless you got some sort of mount that has a voltage regulator built in.
If the plug is the only power input I would get a multimeter and see which contact connects with which wire. I would guess that the center pin is positive but you never know.
John Saunders is offline   Reply With Quote
Old June 10th, 2009, 05:49 AM   #3
power
John,
thanks for your response I thought thats what that plug was that I was holding
the male mini I guess im wrong as far as the regulator I think thats what the box in the background is. the maunal is a joke so I dont know. It has a red wire labeled 12v and a black labed ground. Is it possiable to connect this to a AB connector?
Old June 10th, 2009, 02:54 PM   #4
I'm not sure but I doubt that the box inline for the monitor is a regulator since they normally rely on the power source for the voltage. I would hesitate to just hook up the battery to it. To be safe you could get a regulator from radio shack
+12V Fixed-Voltage Regulator 7812 - RadioShack.com
Put it inline and you should be good to go.
