Shoulder Mounts?
Does anyone know of any shoulder mounts available for the GL2?
Thanks. |
These are the 2 I have heard from on these forums and am looking into myself for my GL2
http://www.varizoom.com/pages/lsp.htm http://www.marztech.com/ Both look like they have advantages and disadvantages. The delemias of this hobby, $$$$$ for everything. |
Whoa! Thanks for the reply, but those prices are absurd! Guess I'll live with a tired arm for the time being :)
Yeah the sticker shock on accessories for this hobby have taken a bit of getting used to. I was not planning on a shoulder brace yet, but after shooting some footage and realizing that after a few minutes the images start getting a little shakey as the cam tires the arm I figure I will opt for something soon. I may go with a monopod to help in the short term.
Hi Guys. I use a monopod for sports shoots and I find them better than shoulder mount
Jus' for whatever it's worth I tried both and prefer the monopod for stability. The shoulder mounts, besides the lack of comfort, translate too much user biological effects (breathing, coughs, burps, hiccups, etc.) to the camera.
They are great for short term shooting like NG work but over the long haul they are uncomfortable. Monopods have their drawbacks too. Thier heads are usually awful and even if you find a good one with decent dampening you will find that as you tilt or pan you can overcome the stability of the monopod itself! In other words the more stiff the head the more likely you are to lose stability in the monopod. Someone needs to come up with a quadrapod with a fixed footprint of say 6 to 10 inches. It would greatly reduce the inadvertant user tilt and lean from the monopod design and still allow for close phyisical user contact. Off to bench! |
www.habbycam.com - can't beat those prices!
Those prices are a lot more reasonable. Thanks!
Marztech
Have to say the Marztech equipment looks great. i am fairly short, so have trouble with fatigue when shooting stable high shots for prolonged periods of time
i would think it would not be too hard to make your own marztech setup by modifying a rucksack with a decent aluminium frame. they cost aorund £70 here, and are probably chepaer in the states. one could rivet/bolt/weld (altho i know welding onto aluminium is difficult) the upper, curved support after all, the marztech is a failry simple piece of kit as an XM-2 owner, I have to admit to being an accessory addict. I found one of my most useful purchases was a flashgun handle, which i use use to give me better support. It also helps me keep the cam level when holding it abvove my head. |
re
Has anyone experimented with the Varizoom Media Pro? How does it work with the Canon MA-100 adapter?
