Multrig setup questions
Prepping my HVX/Mulit rig combo - nice work, Danny. Wondering how to attach a zoe zoom contol to right front handgrip. Must I slice off an inch of handgrip foam?
HVX/Multirig combo is a little shaky when attached(collapsed) to my sachtler tripod. Camera jiggles when I touch it. not good. too springy. Not sure about a solution, but I think if I stuff a wooden wedge or something under the camera screw it might help . |
Chris,
I found the same thing with the tripod issue. My canon H1 is heavier than the HVx, and it was also springy. For now, I put a manfrotto 577 adapter where you would mount the camera, and slide the camera in and out. Tell me if you figure omething out to be able to keep that arm from springing up and down. The multirig is quite impressive, but I haven't used it on job yet(need to get more used to it before hand). I find that to use it in what Danny call the "stabilizer plus mode" with a camera as heavy as the H1, you have to really tighten the arms with the allen wrench. If not, the camera pushes on the pod in towards the belt holster, and the arms pull in to your body. I also tried it with my Sony FX1, and it works like a dream. I think the multirig is better with a camera similar in size to the Fx1, HVx, DVx etc. I wonder whether the dv rig xl would be better for the loaded H1. But on the other hand, the multi can be configured so many different ways...I need to work with it a bit more to decide. i must say tht it's great buying from a company like Danny's. The concern for customer satisfaction is refreshing in today's market. Bruce S. yarock www.yarock.com |
Danny,
You mean put the cork underneath, between the folded grip and the arm? Bruce S. Yarock www.yarock.com |
After you enjoy the wine, Has to be a good one.. you cut the cork to size and place it between the bottom of the main bracket and the folded arm.
I'll drink to that ! What about using my zoe zoom control on the handgrip?
Any recommended workaround? When I clamp it around the foam handle, it twists/turns when I try to zoom. thanks, chris li/metro wash. dc |
Danny,
I stopped drinking 20 years ago, so I guess I'll have to find a wino to help me out.I'd ask my parents but Manischevitz Wine doen't use corks. Bruce S. yarock |
Chris,
That's curious. I have the DV Rig Pro complete with foam handles - using a Manfrotto lanc controller. When attached (over the foam) it locks down without any play or slippage - it's just there - period - rock stable. Isn't a foam handle a foam handle? Different materials maybe? Perhaps the secret is to always wear a blue shirt - I do and haven't had any issues. Hey, give a try - what do you have to lose? George |
is on the same surface as the rocker lower section. You have to find a piece of hose or plastic pipe, cut a slice as long as the zoe body size (without the rocker) cut a slot in the pipe and clamp it on the foam grip, when you clamp the zoe over that pipe, the rocker won't touch the foam and you can tighten harder. if the pipe is too thin you can put few more layers until you get it right. Another solution is to cut part of the grip foam and clamp the zoe straight to the inner aluninium tube. |
Hosed
"find a piece of hose or plastic pipe"
Thanks for the tips, Danny. You've thought this all out and saved me from re-inventing the wheel. What about this one? I tried to leave my Sachtler tripod plate attached to multirig but it's too wide to fit between the collapsed foam handles. My apparent solution is to switch to the narrower bogen 577 quick release assembly as bogen plate will just fit. Any way to stick w/sachtler plate? |
[QUOTE=Chris Li
I tried to leave my Sachtler tripod plate attached to multirig but it's too wide to fit between the collapsed foam handles. My apparent solution is to switch to the narrower bogen 577 quick release assembly as bogen plate will just fit. Any way to stick w/sachtler plate?[/QUOTE] Chris, I do not see the problem with a wide plate ! the plate bracket is lower then the other arms. Pls mail me a clarification photo. |
Sachtler plate
Problem solved. I had the 2 collapsed outside handles facing wrong direction.
Once I rotated them 180 degrees plate fit fine. Still looking for the right cork. Next bottle of Pinot Noir might do the trick. |
Chris,
A word about Danny - still haven't decided what I'm more impressed with - his product or his service. He's a rare find! Enjoy the rig. George |
