MAC mini as CineformRAW recorder
...just replace cpu to merom core 2 duo 2.16Ghz :)
Apple Core Solo to Core Duo upgrade. Mac Mini’s brain replaced with a Core 2 Duo |
Now that's an interesting development!
The Merom 2.16GHZ Core 2 Duo will likely be our recommended configuration for Silicon recording. This will give us some headroom to deliver more features and capabilities. |
FYI, Ari is talking about the next gen Core Duo chips coming out.
http://www.macrumors.com/pages/2006/...21145043.shtml heath |
New CineformRAW recorder solution is a MiniPC (Small Form Factor) Aopen MP945-VXR based on Merom. http://global.aopen.com.tw/
Need Dual DDR2 667 Memory
The limitation of this Aopen architecture is the single memory bus which is limiting overall memory bandwidth. The 945GM integrated graphics uses the common memory and becomes a bottleneck for the demanding HD perfromance. We tested this architecture on Core Duo (Yonah) and it could not keep up.
My mistake. I need to read specs more carefully...Thank you, Ari!
What you can say about Commell LS-570 5.25" Core Duo Embedded Miniboard? |
