X70 4 audio tracks?
I'm editing XAVC in Premiere Pro CC (feel free to move this Mods if should be in the Adobe cc forum) I get four audio tracks, two of which are empty. Is there some setup in the X70 that I can use to just get two? Failing that is there an easy way to get rid of the blank audio tracks in Premiere CC? I cant seem to just delete them.
Re: X70 4 audio tracks?
No way to disable the extra tracks in camera as far as I know. However, in Premiere Pro you can right-click on the source file and select Modify > Audio Channels. From there you can uncheck channels 3 and 4. Alternatively, once you have created a sequence using the source footage you can delete any audio tracks from the timeline that you don't want.
Thanks Mike, finally figured out how to do that. CC seems to have changed lately, everything's different in the sequence header.
I didn't think the X70 could record 4 channels. When I tried the X70 for a day all the files are just 2 channel PCM just like the spec still says and EDIUS shows only two channels present on the XAVC-L files I shot. I checked spec and it does not even have Dolby 5.1 for AVCHD which the consumer cameras have and would give 4 channels. Must be a Premiere issue ?
Ron Evans |
All my XAVC files have 4 audio channels, but of course you can only record to two of them. Perhaps EDIUS detects 3 and 4 as empty and discards?
I just opened up an MXF file copied straight from the X70 to my Mac, and opened it up in MediaInfo which confirms 4 channels of audio: General Complete name : ...../Clip0001.MXF Format : MXF Format version : 1.3 Format profile : OP-1a Format settings : Closed / Complete File size : 682 MiB Duration : 1mn 50s Overall bit rate mode : Variable Overall bit rate : 51.9 Mbps Encoded date : 2015-09-29 15:28:44.000 Writing application : Sony Mem 2.00 Video ID : 2 Format : AVC Format/Info : Advanced Video Codec Format profile : High 4:2:2@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Format settings, GOP : M=3, N=15 Format settings, wrapping mode : Frame Codec ID : 0D01030102106001-0401020201316001 Duration : 1mn 50s Bit rate mode : Variable Bit rate : 47.3 Mbps Maximum bit rate : 50.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 10 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.761 Stream size : 621 MiB (91%) Transfer characteristics : BT.709 Audio #1 ID : 3 Format : PCM Format settings, Endianness : Little Format settings, wrapping mode : Frame (AES) Codec ID : 0D01030102060300-0402020101000000 Duration : 1mn 50s Bit rate mode : Constant Bit rate : 1 152 Kbps Channel(s) : 1 channel Sampling rate : 48.0 KHz Bit depth : 24 bits Stream size : 15.1 MiB (2%) Audio #2 ID : 4 Format : PCM Format settings, Endianness : Little Format settings, wrapping mode : Frame (AES) Codec ID : 0D01030102060300-0402020101000000 Duration : 1mn 50s Bit rate mode : Constant Bit rate : 1 152 Kbps Channel(s) : 1 channel Sampling rate : 48.0 KHz Bit depth : 24 bits Stream size : 15.1 MiB (2%) Audio #3 ID : 5 Format : PCM Format settings, Endianness : Little Format settings, wrapping mode : Frame (AES) Codec ID : 0D01030102060300-0402020101000000 Duration : 1mn 50s Bit rate mode : Constant Bit rate : 1 152 Kbps Channel(s) : 1 channel Sampling rate : 48.0 KHz Bit depth : 24 bits Stream size : 15.1 MiB (2%) Audio #4 ID : 6 Format : PCM Format settings, Endianness : Little Format settings, wrapping mode : Frame (AES) Codec ID : 0D01030102060300-0402020101000000 Duration : 1mn 50s Bit rate mode : Constant Bit rate : 1 152 Kbps Channel(s) : 1 channel Sampling rate : 48.0 KHz Bit depth : 24 bits Stream size : 15.1 MiB (2%) Other #1 ID : 1-Material Type : Time code Format : MXF TC Time code of first frame : 00:28:15;07 Time code settings : Material Package Time code, striped : Yes Other #2 ID : 1-Source Type : Time code Format : MXF TC Time code of first frame : 00:28:15;07 Time code settings : Source Package Time code, striped : Yes Other #3 ID : 7 Format : Acquisition Metadata Muxing mode : Ancillary data / RDD 18 Duration : 1mn 50s Frame rate : 29.970 fps Other #4 Type : Time code Format : SMPTE TC Muxing mode : SDTI Time code of first frame : 00:28:15;07 |
I looked at the files again with Catalyst Browse and as you say it shows 4 channels. Took into a stereo project in EDIUS and it only had the 2 channels with audio even though I know that a 5.1 file will place the other channels even in a stereo project. Created a 4 channel project and the other X70 channels appeared with no data !! I wonder if this is an MXF spec issue even though the X70 only records 2 there are 4 in wrapper.
Ron Evans |
I think the MXF spec is 4 channels as was common with XDCAM MXF.
In FCPX there's a input setting that automatically removes empty audio channels. If that's not enabled I see 4 channels when importing XAVC-L as well. I don't think this is an issue (bug) so much much as the nature of Sony's MXF spec which must be complaint with their other cameras. |
