PXW-X70 PP Comment
Just wanted to chime in on using Paul Anderegg’s custom PP posted back on 11-06-2015 found below and http://www.dvinfo.net/forum/sony-4k-...-settings.html with my PXW-X70, shooting in 4k. If your chimed in Paul, “Thank You” for that PP. I used this PP at a Christmas play last year with the exception of the Black Gamma set at Middle & 0 and using auto white balance. Everything came out extremely clear along with color, even in scenes where a fogger was used. The only exception was a few scenes with a fogger being used with red lights. Those scenes along with faces were washed out about 40% along with a small amount of rolling shutter. I will be filming the same play again this year, in the same place. If anyone has any suggestions/idea’s for me to help clean up the reds, or changes in the PP, I would sincerely appreciate it. Other than that, the PP worked awesome.
BLACK LEVEL: 0 GAMMA: CINEMATONE 1 BLACK GAMMA: HIGH +7 DAY / LOW +7 NIGHT KNEE: AUTO 90% HIGH SENSITIVITY COLOR MODE CINEMATONE 1 SATURATION: 0 COLOR PHASE 0 COLOR DEPTHS: 0 COLOR CORRECTION: COLOR REVISION MEMORY SELECTION: 1&2 MEMORY 1 COLOR PHASE: 9 PHASE RANGE: 4 SATURATION: 0 MEMORY 1 REVISION PHASE: +8 SATURATION: 0 MEMORY 2 COLOR PHASE: 18 PHASE RANGE: 7 SATURATION: 0 MEMORY 2 REVISION PHASE: -15 SATURATION: 0 WB SHIFT FILTER TYPE: LB-CC LB [COLOR TEMP]: 0 R GAIN: 0 B GAIN: 0 DETAIL* LEVEL: 0 MANUAL SET: OFF |
Re: PP Comment
This is my newest PP, post #18, see how you like it. :-)
http://www.dvinfo.net/forum/sony-4k-...ml#post1937606 Paul |
Re: PP Comment
Thanks Paul..... When using your updated PP, should I leave all the other settings the same as in the previous one I used? I sincerely appreciate all your help you have given me to make my shooting successful. That Christmas show is coming up quick....... Thanks again, Ray ;)
Re: PP Comment
Set the phase and saturation to 0 for the new one, you can change whatever else you desire, this would just be custom COLOR CORRECTION MENU settings for REC709 color mode :-)
Paul |
Re: PP Comment
Hi Paul,
Back home and will give the new PP a try. Thanks for all the time you put into help us with the Z150 PP. |
Re: PP Comment
Re: PP Comment
