Blenheim Palace, England
Re: Blenheim Palace, England
Kevin, how is the a7s? Do you like it, about to pull the trigger on two for my 5d3 and 6ds. But just a question, your footage looks the same as my hfg25/30 a bit soft, is that the lens or? steve
I find You Tube very strange. The same item on my channel is without doubt sharper than the link posted here. Why? I don't know...very strange. On a HD monitor it's pin sharp.
The A7s is a great little camera, but it does have its well documented pros and cons, I like it because I can use it almost unnoticed at times, but then I don't have a large rig, etc. |
cheers Kevin
For some strange reason, You Tube has the default setting on my channel/homepage as 1080p but on the link it's at 720p and you have to click the HD button to change it which doesn't help matters!
