Fast wide autofocus prime? AKA $900 mistake at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old September 29th, 2015, 07:04 PM   #1
I just realized my Sigma Art lens in 35mm F1.4 in A mount I just bought new for my FS700 cam using the Sony adapter will not open up wide than the maximum F2.8 of the LAEA adapter. I bought it specifically for it's low light speed. This now makes it totally redundant to my Sony Zeiss F2.8 18-35mm.
Now that's a $900 mistake. :(
So who makes a fast 1.4 very wide zoom in E-mount that autofocuses? A FF 35mm won't be 35mm FOV on a Super35 sensor, so I may need either a wider FF lens recommendation of a fast 35mm for Super35.
Dave -
Dave Allen is offline   Reply With Quote
Old September 29th, 2015, 09:44 PM   #2
Re: Fast wide autofocus prime? AKA $900 mistake
Sony makes a 35mm f1.4 in E mount.
Distagon T* FE 35 mm F1.4 ZA | SEL35F14Z | Sony US
http://www.LandYachtMedia.com
Old September 30th, 2015, 11:27 AM   #3
The FE 35 is awesome, but it'll be a ~52mm FOV. Another option is the E-mount Zeiss 24/1.8, which is the closest native lens to the 35/1.4, just a stop slower.
http://www.bhphotovideo.com/c/product/818647-REG/Sony_SEL24F18Z_SEL24F18Z_24_mm_f_1_8.html
Can be found used for around $600 if you are patient.
Chris Joy is offline   Reply With Quote
Old October 2nd, 2015, 02:43 AM   #4
Is there a reason the LAEA3 wouldn't work for you? What is the special purpose/feature of the other version you have that is more expensive?
Paul
Old November 21st, 2015, 10:17 PM   #5
I think all of their LAEA autofocus adapters default to F2.8 at its fastest, so if you have a faster lens, it will be of no value if you need to open it up beyond F2.8.
Dave -
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
