Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony NXCAM / AVCHD Camera Systems > Sony AVCHD NEX-VG10 / NEX-VG20
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old May 22nd, 2013, 05:07 PM   #1
NEX VG30 chroma subsampling
Hello,
Does anyone know whether the VG30 uses 4:2:2 subsampling or 4:2:0?
I believe I read that the VG900 uses the former, and aside from the sensor they appear to be fairly similar.
Thank you in advance.
Ron Wilk is offline   Reply With Quote
Old May 23rd, 2013, 10:32 AM   #2
Re: NEX VG30 chroma subsampling
The VG series all "print" 4:2:0 to the SD card. I've seen nothing to indicate that the VG900 prints 4:2:2 to the SD card (it's not on the B&H or Sony website that I could find, and it's not listed in the manual).
Many people have stated that they believe the VG lineup does output a 4:2:2 signal if recording to an outboard hard drive (like a Ninja). Haven't tested myself, but I'd say it's a good bet it does.
Be very wary of assuming that Sony will stay consistent with their different cameras - even if they use they exact same hardware - I believe that they tinker with every single model just enough to make each unique (although the VG20/30 are quite close).
Unlike the Canon DSLRs, which all seem to be more or less cut from the same cloth in any particular generation, there can be major differences with Sony.
John Vincent is offline   Reply
Omega Broadcast
(512) 251-7778
Austin, TX
Z.G.C.
(973) 335-4460
Mountain Lakes, NJ
Abel Cine Tech
(888) 700-4416
N.Y. NY & L.A. CA
EVS
(800) 238-8480
Glendale, CA
Precision Camera
(800) 677-1023
Austin, TX
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony NXCAM / AVCHD Camera Systems > Sony AVCHD NEX-VG10 / NEX-VG20
Google
1998-2015 The Digital Video Information Network
