XD Cam HD...Worth the price?
I like the XD Cam tapeless workflow but I can't wrap my head around the price.
For the price of one F350 I can get 2 Canon XL-H1s and an A1. For all of you independant producers/editors/shooters does the workflow advantages make up for the large cash outlay? If you had to do it over again would you still purchase an XD Cam system or go with something less expensive and tape based? |
Picture-wise, the camera is stunning. You might not think that 35mps would make that big of a difference, but it does. It has to to with the variable rate, and how it is allocated to the picture.
24 p is lovely. Seldom need to use detail on this or 60i. Depth, latitude of larger chip Working with a real broadcast lens Workflow-wise, I think we're just beginning to scratch the surface with the proxy system. I'm already able to deal with selects and sharpen my choices while hanging with the laptop in the living room. It makes a big differnce and saves tons of time in edit booth. So you're going to save some of that difference in bucks in faster edits, and more sanity in your life. And there's a reason flks like Discovery have approved the camera and the codec. |
In my case, the budgets for work I was getting higher, high enough that I wasn't comfortable anymore shooting the JVC HD100 and hoping I wouldn't have some weird post problem crop up. On one job I discovered the dreaded TC break issue with FCP, and it threatened my ability to get the project done on time. So I guess my answer is, buy the camera if you can bill back for it! If not, then don't. |
Kevin, the two XDCAM HD cameras the F350 and F330 are both in a different league to the XLH1 in every respect, especially picture quality. I've done extensive tests between the JVC GY-HD111, XL H1, Z1 and HVX200, they are all kind of the same ball park really, JVC and Canon coming out slightly on top in the picture quality department. When comparing the F350 to the JVC it is miles ahead. It makes the JVC look like cheap PixelVision, JVC is all blocky, harsh, very pixilated with hard edge enhancement and a ton of green fringing (lens admittedly) thrown in. On a large HD monitor you can clearly see where the extra money has gone.
The 35Mbps variable makes a huge difference, just ask any professional colourise how much they can pull out of that compared to a Z1. I know a pro Soho colourist in London and he says he can pull a ton more out of XDCAM HD than he has ever been able to get out of a Z1 or high-end DVCAM such as DSR570; says F350 is miles better for his job. Another reason XDCAM is superior in image quality is the 1/2 inch blocks and lenses and the superior circuitry and on-board processing units. All of which are miles better than anything in the XL H1. Discovery HD has approved XDCAM HD as a 100% acquisition format, they simply turned down XL H1 as it is just nowhere near good enough; same goes for the remaining 3 prosumer cams costing around £4000. At the moment XDCAM HD is the only TRUE tapeless workflow from acquisition to final master, the rest (P2, Firestore, whatever) are simply tapeless acquisition formats. What I mean by this is that the with the rest all you end up with is a bunch of meaninglessly named clips and large video files; which is tapeless in its most primitive form. With XDCAM HD you name the first clip, then it automatically sequencially names all clips thereafter, until you change clip name again. This way in post you have a bunch of named clips that make perfect sense, and proxy files too. Nothing out there comes close to this well thought out workflow. For me, XDCAM HD is too cheap considering what you get. A DSR450 is the same price as an F330; I know what I'd go for. |
When considering the cost you should also factor in the cost of things like blank disks, suitable tripod, batteries etc. These are all more expensive than the HDV counterparts.
Having said that... As others have said XDCAM is such a massive time saver. On a simple corporate SD shoot just yesterday I was able to delete all the bad takes as we went along. The end result was I only had to go through 15 mins of rushes to put together the final 10 min edit. Transfering the footage to the edit suite took less than 10 mins and the dit only took an hour. I know the same job shot on tape would have ended up with around an hour of rushes, the edit and transfer would have taken longer. So if time is an issue the XDCAM is a big saver. I have also found XDCAM to be a more robust and reliable recording medium. Drop-outs which on several occasions have ruined HDV shots just don't happen, so on critical shoots where you only get one chance to get the shot can you afford to shoot on HDV? Nate is quite right though, it's good to have the latest toys, but if your running a business they will have to make money for you. I now shoot almost everything in HD. I sell more stock footage because of this, so I am making more money. For me the extra outlay over HDV was worth every last penny. |
Yes, I'd forgot about drop-outs. I have just got to the end of a 3 month shoot using two JVC GY-HD111 HDV camcorders and I had a few clips ruined because of drop-outs taking out quarter of a second to half a second of footage; had to go back and re-shoot, 300 mile round trip.
I use a Vinten Vision 8 with F350 and find it is a marriage made in heaven; balances to perfection. |
XDCAM HD is in a different league to XL H1; a professional league. |
I'm now in the XL H1 vs. XDCAM HD debate as well. I do corporate work and am close to sealing a contract for my first HD production. I've pretty much narrowed it down to these two cameras. For the XDCAM HD users out there, what's the "cheapest" entry into this arena? I assume the 330 plus a decent lens. What lens would you recommend (given the issues with soft corners I've been reading about). I'd love the 350, but the extra 5-7k would buy a good lens. Also, will I need the deck initially, or can I use the camera until I can afford the deck?
Also, how does SD look for this camera? Right now I'm using a 1/2" DV camera (Panasonic) with good results. Will the Sony do better due to newer technology? I'm going to DV Expo next week... I hope Sony has the 330/350 there! I'd also love to see the Grass Valley camera too! Stuart |
Remember, XDCAM HD is Proper HD, it is not HDV, which is 25Mbps constant. So you can quote to your clients that you are using Proper HD and not the consumer HDV; that carries weight.
F330 with Canon 19x SD lens is a great combination. Prestons in the UK are selling this combo for under £10,000 inc VAT. F330 in SD mode is identical to what you would get out of a high-end DVCAM model like the DSR450, only the audio on the F330 is better as it is 16-bit, unlike DSR450 which is just 12-bit. |
Is that the YH19X6.7IRS14 1/2 inch lens? |
Quick input after a quick read of this thread...
It's not my place to convince anyone that an XDCAM HD (330 or 350) is the way to go. BUT We bought the 350 after extensive and in depth research into FUTURE potentials - such as distributing to Networks, or on HD discs (whether Blue Ray or whatever)....or outputting via SD to current DVD/TV requirements. The phrase "future proofing" got our attention. What we shoot today can go out in any format required today - but can still be put out in true HD in the future (stock shots for instance are in demand right now in HD...and there'll be an increasing demand in future). The F350 had the edge because of interval recording/slow mo - and a few other bells and whistles such as 4-channel-sound, an excellent viewfinder, the ability to do thumbnails and in-camera EDLs and so on. As for lens choices...keep watching this forum....the guys who share their lens testing knowledge are worth their weight in gold...your gold:-) We can ingest directly from the camera to the Mac (where we opted for Final Cut Studio) and on a High Def screen, which I watched for the first time this week, our pixels and pictures are just wunnerful. There's a weight and balance issue to consider - but if a Vinten tripod is a marriage made in heaven, then I wish I'd known that a few months ago:-) The disc recording medium is a HUGE money-saver. They're only $US30 each - last 50 years - can be recorded over 1000 times - take up no room at all in stgorage...and with the new PDZ-whatever transfer software, and the things that are built in to FCP, you never lose track of the original shot!!! In our situation, which was a case of starting from scratch, which meant we had no prior investment in other formats, it made absolute sense to go with the XDCAM HD with its 1/2inch lenses (better pixel capture/more of them) BUT it also meant, because the camera is really a computer that we did not have to buy all the expensive decks that Sony also suggests are required. We go straight from the camera to FCP.... FYI - having an AJA board helps a lot in editing..... But back to the "choice." In the US at least, HD is the next level....and all the channels want it...and anyone who can offer anything of reasonable quality is likely to find that the XDCAM HD was definitely a good investment. Michael KNight. |
I've always been suspicious and critical of Sony's marketing claims, but after shooting XDCAM HD on two projects (one exteriors and time-lapse, the other hand-held shooting of an event) I'm convinced, XDCAM HD might really be "the next Betacam SP" in terms of a high-quality format that is robust, cost-effective, and potentially unversal for professional imagemaking.
The new XDCAM HD camera is amost everything I've ever wanted from a professional camcorder: true progressive imaging, variable frame rates, time-lapse, image control, etc. Still, I'd like to see a 2/3" camera shooting this format, but that's just a matter of time, as well as a smaller camera too. HDV is simply too brittle of a format and the data rate is a tad shy. The HQ mode of XDCAM HD is enough for the most critical viewer. I'm truly impressed with the F350, it's the first Sony professional camcorder I really like. Since the introduction of the Panasonic Varicam it's held the position as my favorite camcorder in the 2/3" category, the F350, even though it's only a 1/2" camcorder, is really charming me... it's a truly impressive camera. HDV is a good format, and a great value for the money, but if you need something more... there are now two good formats to choose from, DVCPRO HD from Panasonic (with P2 or HD recording) and now XDCAM HD from Sony (with optical disk recording). |
I had a Canon H1, great camera loved it, until I got my f350. The Sony is in a differnent league, far better for many, many reasons.
Consider that XDCAM HD has only been available to buy for around 6 months in the UK, then talk to dealers about how many they have sold. It's gone from a format that most had not heard of to a best selling product line in a very short period. I also belive that this could be the new Betacam, pehaps replacing all the DSR500's and 570's that are ou there doing SD work now. Even if you only shoot SD the workflow advantages are considerable. |
XDCAM HD has really taken off in the USA, but is a bit slow catching on in the UK. I put this down to the fact that people just don't understand it and Sony are having a hard job educating people. Though in the past 2 months here interest and sales have really started to skyrocket.
There is a lot more to XDCAM HD other than picture quality alone; which is simply in a different league to the Canon XLH1. It is the only format on the fact of the planet that is a total 100% tapeless workflow from acquisition to final master. The competition are simply tapeless recording formats, that's where it stops. XDCAM HD uses a really intelligent and well thought-out tapeless workflow with automated clip-naming, clip lists, meta-data lists made from proxy files. This is just the tip of the iceberg. The competition (P2 and devices like Firestore) are extremely primitive and dated in comparison. You really have to use XDCAM to totally understand and fully appreciate it. But once you have you will never go back. I agree with Alister, I think XDCAM HD is the new Betacam. I see it replacing not only the DSR450 over time, but also Digibeta too. And this is in its current 1/2 inch form. |
I'm curious if any of you that owned/used a Canon XL H1 ever compared HD-SDI footage from the Canon to 35mB/s footage from the XDCAM HD? If so, was the 330/350 still much better than the Canon? Also, does anyone ever capture HD-SDI from the 350, or is the quality straight from the camera's discs that good?
As much as I had wanted to see the XDCAM 330/350 at the DV Expo, Sony decided the show was not the proper forum for the camera. ProMax had a 350 at their booth, but no footage was available for comparison purposes. Sony's booth was clearly focused on the new V1U. I've got to admit that XDCAM HD along with a V1U for those hard-to-reach areas seems like an intriguing combo - at least in progressive mode. The V1U's interlaced footage seemed a bit soft to me. Stuart |
330/350 images surpass the H1 quality by quite a long way. I've used both and I won't be using the H1 again unless I have to. The 35mb XDCam outperforms the H1 in every respect apart from price.
Thanks for the response. As I move closer to the contract for this HD job, it amazes me how many equipment decisions I'll be making. If I decide to make the investment in XDCAM-HD (which is certainly what I'd prefer, if money were not an issue), I'll need to re-evaluate my editing situation. I'm using the Adobe Production Suite for my SD stuff now and have been 95% happy with it. With XDCAM HD, there really is no reasonable route with PPro 2.0. It's either on to Vegas 7.0 (don't want to) or FCP. FCP is probably my best route, since I'm a big After Effects user. Much of my work involves motion graphics. From what I've read, AE is nicely supported with XDCAM files in the Mac environment. A new Mac Pro could give me the best of both worlds...
I lean towards the 330 and a good lens, since I will not be doing anything beyond corporate work. I don't think I can justify the extra $8000 or so for the 350's features. Any thoughts on the 330/350 for corporate from users of both cams? Thanks. Stuart |
I had both an XL-H1 and F350 at the same time. hen the F350 arrived the XL-H1 went back in it's box and never came out again. The XL-H1 is a superb camera but it just isn't in the same league as the F350/F330. There are so many advantages to the XDCAM's over the H1, not least of which is picture quality. The F350 is considerably cleaner and has more dynamic range. In my opinion the H1 has a slightly odd looking colourimetry. 35Mb XDCAM holds together soooo much better in post than 25mb HDV, the extra 10Mb and the variable bit rate allocation makes the format much more robust.
Once you switch to a file based system (at least a reliable, bug free system) there is no turning back. Instant clip access, easy clip managment etc are just wonderful. I made the switch from PC's to Mac's for XDCAM and have no regrets. In fact I have just ordered a new Macpro to replace my G5. I love being able to edit while still ingesting footage in the background. As for the F350/F330 debate, well there isn't much difference except the viewfinder. The 1.5" VF of the F330 is not up to the job for HD, it's way to small especially as it is a 4:3VF so you get a tiny letterbox image to squint at. If you go for the F330 I strongly recommend you get the 2" VF upgrade. If you don't need overcrank or HDSDi then the F330 will save you some money, if you can live with the silver colour. |
if you can't live with the silver colour (which is much nice in the "flesh") but a Petrol wrap for it like I have!
having component out saved me buying the more expensive SDI Marshall monitor too! |
Keep in mind that Adobe has not yet released a After Effects Universal version to run on the MacPro. I called Adobe and they say the Universal version of AF will be some time in first quarter '07. |
Thanks for all the responses. If the contract comes through for the price I'm expecting, the 330 could be the one. I agree the XL H1 is a great camera for a 1/3" HDV system, but I will always choose higher picture quality if I can afford it.
Regarding a universal copy of After Effects 7.0, thanks for the heads up. I know Motion has some nice features, but I'm too heavily entrenched in After Effects to walk away (not to mention 9 years of experience in it). As the time approaches, I'll post my final decision. Until then, I'll enjoy the great information on this website. Stuart |
The 330 is an amazing camera. Ignore the superior picture quality, optics etc...the disc format alone is worth the price. Never again will you lose an important take or shot due to flimsy mini dv tapes.
The 330/350 are pro cameras accepted by broadcasters. The H1, although capable of terrific pictures is not accepted by all broadcasters, will not impress corporate clients anywhere near as much as the xdcam. Let's not ignore the fact that you can shoot in progressive mode which the H1 does not support. As corporate is the big part of your work, the XDCAM will blow them away! The H1 is overpriced, in picture quality it is pretty much identical to the Z1, yet twice the price. |
The H1 does shoot progressive, in much the same way as the F350/F330 and the picture quality of the H1 is better than the Z1, I know I've owned both. The H1 and Z1 are very different cameras. I don't think the H1 is over-priced. If you use one you start to realise what you have paid for, things like proper manual control switches and knobs, not menus and push buttons. Timecode in and out, HDSDi, useable 4 channel audio with 4 inputs, adjustable colour matrices, dial-in white balance, white balance offsets etc etc. The very things that differentiate between a handycam and a Pro camera.
I never found HDV to be flimsy. Yes, drop-outs can be an issue but they are not normaly a big problem unless you have dirty heads. I've used HDV cameras in some pretty horrendous weather, bolted them in all kinds of aircraft, rollercoasters, rally and race cars and they have always delivered the goods. My corporate clients love XDCAM. Most of them don't really understand the difference between being tape based and file based, but when they ask to review a take and you press one button and are back at the start of the take it impresses them, as does the picture quaility in both HD and SD. |
For Adobe Premiere support of XDCAM HD, see http://www.videotechnics.com/products/xdcam_vt.asp
Hi Bart,
Did you tried the plugin? Did it work? I´m looking for, and waiting for a Premiere solution for XDCam HD editing. Thanks. |
Last time I checked that plug-in only worked with SD XDCAM decks connected using Ethernet.
I was trying to make it work with some XDCAM clips that I got, but so far - no success. I'm waiting for the answer from their support. We'll see.
Essentially what we need is an AVI wrapper for MXF files... Shouldn't be that hard to do. I sincerely hope that blackmagic will support MXF soon, since we already own Multibridge Pro. |
Any movies shot on 350?
Does anyone know if there are any movies shot on 350 or 330?I would like to know if it would be a good choice to go with 350 instead H1 for my feature.
JK |
The 330 is a much better choice for your feature than the H1 for all the reasons listed above!
Thanx dude.But I wanted to see a movie shot with that.I guess I will be the first one to do that.
JK |
feature
I'll be finished editing this feature by the end of the year
http://www.theincurable.com has some stills. and a 1.5 hour doc for PBS by Feb. Also segments on this soon to be national arts show. http://www.klru.org/incontext or http://www.incontext.tv The 330 and 350 in 24p, 35bit are an indie dream come true. If you have a script and the money and can't wait for RED, rent one of these. |
The images look incredible.
What lensing did you use? Did you use a P+S or M2 adapter? Aloha, Keith |
Thanks Keith.
I have the HSs18x5.5BRM Fuji. No adapters. For the feature, I tried to shoot about 3/4 of the way zoomed in whenever the situation/ space allowed to avoid the worst of the CA and get as much shallow DOF as possible if the scene called for it. It's a good piece of all-around glass for the 330. I wouldn't want to spend any more unless I were moving up in a camera as well. Again, this is the camera that I would have (insert over-the-top phrase here) for about 10 years ago. The only reason I can think not to use this system for a low-budget feature is if you're wanting to air on HDNet. Even though Bubble was shot on HDCAm at 1440x1080 3:1:1, they only accept 1920x1080 from people outside their system. And you will never fool them becasue the 1440 multiburst falls apart when compared to HDCAm SR. For HBO, Sundance and others where content is more important than specs, this camera is more than fine. |
Thanx Dutch that was awsome.I can't wait to see that on a big screen.You got a 35 mm print right?I hope you do.
Anyway keep up the good work man. |
You're telling me HDCAM is not good enough for HDNet? HDCAM SR only? I was under the impression HDCAM SR was 1440x1080 anyway, with the only improvements (not to diminish them) being the options of 4:2:2 or 4:4:4 color. The 4:2:2 mode is lower compression than reg HDCAM. |
Hey Jimi,
I'm going to try not to have to print out to 35mm. DLP in Landmark, etc instead. All of the equipment and most of the locations were borrowed on weekends and nights. The total budget came in under 7K (I paid actors $100/day indie SAG rates to be legal, fed everyone, media, wardrobe for the leads and a make-up artist for 4 days for things like dinner scenes)... so the 60K it would take to get a decent print just doesn't seem justified... I could 4-wall maybe 6 to 10 markets with press with the same amount of $ using digital projection. And honestly, I've seen Sex and Lucia projected from film and digitally. Guess which looked cleaner, sharper and just plain better? But, we'll see what happens over the course of 2007. Nate, I didn't want to believe it either. But, back in March when I started really thinking about putting this together, the vice pres of HDNet acquisitions was gracious enough to meet with me during SXSW... and that's what I was told. She has to defer to her engineers, who just that week had not let her rent a couple of all-time classic 70's films which had recently run on HBO because the studio's transfer was below their standards. I know thier 1080i 19mb signal resqueezed and resized on everyone's 720p home screens isn't going to look any better from 4:2:2 1920... but they're trying to sell to the boys with the latest toys who think bigger numbers means better picture. And, I suspect it's more of a filtering process to keep from having to preview a glut of ultra-low budget features with little potential viewer interest, which I certainly understand. |
Hey Dutch good luck.
Looking forward to see you do other stuff. XD rocks |
I certainly believe what you were told, but since I've had execs from other large broadcasters mess up specs that they were supposed to be relaying to me...I dunno. That sounds crazy. Most post houses here in LA working in HD have HDW-500s, D5s, or Pana 1200As, but not SRW decks. Those are still top, top end.
On the front page of the HDNet site they have a "Tech Specs" link, and a PDF block diagram of what I guess to be some part of the HDNet operation. Why, I have no idea, but...they have a bunch of HDW-500s on that diagram... |
