Unit being thrown into error from quick stop & start
When I push stop and start pretty quickly, which I do quite often, it throws the unit into error.
I then have to shut it down and back on again. Which takes time. When the unit goes into error I might not notice for a while which means I usually end up having to capture in from my tape after each job. Im using the Transcend 133x 32gb. Could these be the reason I wonder? Has anyone else had this problem? |
Hi Ger. I noticed that when I press Stop on my cam, the EVF shows a flashing symbol for the firewire link to the recorder. After a few seconds this stops flashing, indicating that the cam is ready to record again. I expect if you press Start while the symbol is still flashing there is a high chance of record error.
Richard |
Hi Richard,
I have noticed a flashing light on the unit alright. I was thinking maybe the flashing was due to the time it was taking to finish the .avi file on the card and that maybe a quicker card would cause this flashing to last less time. I have adapted my recording habbits in recent times - I basically leave it recording long clips and cut it up later. |
