some of the clip not importing into FCP??
Hi,
I'm using the unit to record on it's own with a Canon HV20 and importing into FCP via Log and Transfer and Sonnet's CF dual card reader (it doesn't work as a dual reader btw in case you're thinking of getting it). Sometimes the import only brings in a certain amount of the clip and leaves the last chunk out. Once it stopped after 20ish minutes and last night stopped importing at around 1hour 3minutes consistently. I think it corresponds with a new m2t being made after every 4GB or so. The only way I could get it into FCP was to encode as QT in MPEG Streamclip first and then import normally. Is it the card maybe?? thanks for any input. Gary |
This May Help
Hi I had a similar experience after looking through all the forums I come across this site,
Apple Final Cut Pro (v. 6.02 - or later) Plug-In for HVR-DR60 and HVR-MRC1 - Version 1.1 (7/31/08) I downloaded the Plug - In and all was good. I also used the same link to download the Plug - In for FCP 7 Sony | Product Catalog - Cameras - Broadcast & Production |
FCP being tempermental with log and transfer...
I have had a little issues using log and transfer in FCP 6. I occasionally get an "uknown error" . It says that the files contain no data. When I transfer them directly they are fine. The workflow I am using now that works best for me is to download the footage to hard drive and use clipwrap to prepare the clips for FCP. It has worked without issue so far.
EDIT: it would seem the combo of 10.5.8, FCP 7.01 does not work for clips beyond the 4 gb FAT32 limitation. I took my work home and the clips imported fine on my home system running: 10.6.2 FCP 7.01 both systems use SonyRecordingUnit111.dmg |
