-   Sony HVR-A1 and HDR-HC Series (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/)
-   -   Two sound inputs on HDR-HC9E (https://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/263503-two-sound-inputs-hdr-hc9e.html)
Grant Johnson August 10th, 2009 04:17 PM
Hi,
newbie here... so hopefully this is in the right place...
Usually I work with a V-1, but have an HDR-HC9E as a number 2 safety camera. For a trip shortly it will be my number one and only.
BUT the sound isn't much for what I'm doing (shooting for a DVD series)
I'd like to use my Rode NTG2 and Sennheiser radio mic with it. BUT - there's only one input stereo socket.
Has anyone any suggestions?
I did try a dual mono to stereo plug I had lying around and nothing at all worked. Is it as simple as a dual stereo to one stereo - and will it lay down two mono tracks or will they just merge into one stereo track?
Using FCP for editing.
thanks for any input!
Grant
John Wiley August 10th, 2009 05:24 PM
What you need is an XLR adaptor like the Juicedlink or Beachtek. That will allow you to set the levels on each channel independantly and each will be recorded to a different stereo track.
I'm not sure about the setup you're using now - I've never tried it!
Grant Johnson August 10th, 2009 05:34 PM
thanks, I'll check those out.
Both my Rode and Sennheiser mics have both 3.5mm stereo jacks or XLR - so either will work - but I need to keep the weight and complexity down, so the 3.5 stereo jacks would be preferred. But in the end - whatever works!
