how to decode the A1 manual
Hi
I was browsing through the A1 Manual, to see what functions I will be missing, when my HC1 arrives in two weeks time. So far black stretch and cinegamma is the main functions I am missing. But I also found this in the A1-manual.
Now - English is not my native language, so I would be very positive, if anybody could decode the above bit from the manual. For now I have no idea, what I will be missing. with my HC1. Thanks and kind regards |
Jos,
I think what it means is that steadyshot function, when ON, reduces the total number of pixels used to capture the image. How much is the reduction I'm not sure. Possibly around 5%. You have to search the forums for the exact figure. |
yes what full-scan essentially does is allow a (slightly) larger area of the CMOS sensor to be devoted to image capture. The thin-ish edge of the area is normally used by the Electronic Image Stabilisation to 'float' the image.
So with full-scan you are using more pixels for straight image capture and so in theory get a slightly better image quality (in theory) but of course you have no image stabilisation so will really need to use a tripod for this to work. Those Sony manuals were so obviously written in Japanese first and then slightly badly translated ! |
Not more pixels, the entire sensor is used.
I don't think any other HDV camcorder has this option at the moment. Is there one that does? |
Thanks for the help. This is not a feature I consider essential. This leaves Cinegamma and black stretch as the main advantages for A1 compared to HC1
So it's my interpretation that in HDV recording, around the actual 16:9 chunk of the sensor used is the thin band used for EIS (used for actual image in full-scan mode) and then that would still leave above and below that a band of pixels not used. - I think the full sensor may be used for 4:3 stills though. i'm uncertain on this though, so if anyone knows for sure on this it'd be nice to know. |
And don't forget also that you get the XLR audio module and short-shotgun mic with A1. And also a cold-shoe mount for direct-mount of external unbalanced mics, or other accessories such as video-light etc. |
It does make sense what you said. Maybe you're right.
