You know that annoying record hesitation?
You know the one...You have your HC1... You line up one that once in a life time shot ...hit record... and the camera blinks standby about 5 times before it kicks into record?? And there never seems to be a pattern. (at least I can't find one)
Well... I may be wrong about this but I was testing my new lanc controller on a tennis match with multiple stops and starts and it never did it one time. Just went right into record every time. I taped about 20 mins. of action with about 50 stop/ starts. (some long intervals, some short) Never did that standby thingy once! Could it be? |
That's weird, I think it might have been coincidence. Unless the controller overides some processes that the camcorder does using the button.
Anyways, I also dispise this as well, but it all has to do with the tape head alignment. If you are recording and stop for more than 3 or so minutes, than next time, it should take a little longer as the camcorder has to realign the head. Usually, when you stop and record again very fast, then it should start normally. I have the A1 and I have the QUICK REC feature set to ON and I really haven't noticed a significant improvement from it. Besides, you run the risk of misaligning the head which could damage ur tape/footage. I think temperature may have something to do with it as well. Cause I seem to be getting different start times when outdoors or indoors. Could be lighting, but I don't see why that would be. |
If it's a head alignment pause, then it makes sense, because I never paused for more than 30 seconds at a time. rats.
