using component
Does anyone know ... if you record using the component cables hooked up to a capture card, by-passing the tape, if the signal still has mpeg2 long gop HDV compression? I imagine it still has the color space of 4:2:0, but I think if I were to hook one up to an HD component IN card I could bypass the compression?
A component signal is analog, so there is no compression by definition. The compression you see would depend on the capture card.
Mark |
but no, you will not get higher resolution or color sampling by using the compenent output--it's just reading the 4:2:0 signal from the HDV tape.
4:4:4 Analog output
The Viper HD camera system does this right out of the box, but you can buy a new Mercedes or Ferrari for less money. |
New Mercedes or Ferrari? That's a huge price difference, haha.
Anyways, could someone explain the whole component input/output, capture card, SDI converter, HDCAM, raid drive thing to a newbie? I don't really understand what any of those are, how they work, or what they do, much less why you would use them. |
