Stu Holmes |
May 12th, 2006 09:39 AM |
Originally Posted by Michael Stowe
This is the MicAttn on the xlr correct? This then reduces by 20db, but is there a way to reduce by less then that?
If it's an attenuator cable then yes it's fixed at 10db or 20db or whatever the cable is rated at. It will connect in-line between your mic and the camera. I think it may be a minijack connection, so you may also need an XLR-to-minijack convertor (or two). not sure about that.
Laurence Kingston has an ME64 and an A1 and he uses attenuator cable so perhaps do a search for posts by him about "attenuator" or "attenuation" and that might give some info from his side of things.
