Connecting the Sony HD1000 to an Apple iMac
Since the Sony HD1000 only has HDMI or iLink Outputs - Any suggestions on how to connect to an Apple imac that only uses FireWire 800?
Is there a HDMI to FW800 converter or am I only stuck with using a Mac Pro with a Black Magic Intensity HDMI Card? Thanks. I cant seem to import any video footage on to my iMac. |
You can connect the 'iLink' cable (which is Sony's name for a FireWire 400 cable) to the FireWire 400 port on your Mac. If your 400 port is already taken up, you can get a 400 to 800 adapter.
The camera probably has a 4-pin plug. Your iMac has 6-pin (FW 400) and 9-pin (FW 800.) I don't know of any 4-pin to 9-pin cables, but I know for a fact that there are 4-pin to 6-pin cables.
FYI the reason the (I assume included) cable has both 4-pin ends is that Sony's laptops have a 4-pin connection (as do others.) Most add-on cards for PCs have 4-pin plugs as well. The benefit of a 6- or 9-pin plug is that they carry power to the device for portable hard drives and such. |
No. For HDMI I think you will need the BlackMagic card.
Black Magic Intensity Pro card ordered and on the way!! http://i73.photobucket.com/albums/i2...W/P4280055.jpg http://i73.photobucket.com/albums/i2...W/P4280059.jpg http://i73.photobucket.com/albums/i2...W/P4280070.jpg http://i73.photobucket.com/albums/i2...W/P4280072.jpg http://i73.photobucket.com/albums/i2...W/P4280075.jpg |
