MRC1K-M2T-Windows Media player problem at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old April 20th, 2009, 02:56 AM   #1
I've recently bought a new computer with Vista installed. So I thought at first this was a Vista problem. But it isn't that simple.
All the mpeg files taken from tape will play on Mediaplayer 11
All the mpeg files that originated at m2t files on the MRC1k don't play at all. This applies to files converted with MPEGstreamclip and those converted with Premiere Elements 7.
A couple of times MediaPlayer has given me a message about a CODEC problem, most times I get a black screen, then after a few seconds get a still from the clip which stays still on the screen while the clip is apparently being played.
Anyone else have this problem and know a way around it?
Canon XH A1; Canon XF100; Nikon D800
Annie Haycock is offline   Reply With Quote
Old April 21st, 2009, 05:36 AM   #2
Things are even more confusing.
I have tried playing a few more clips in MediaPlayer. It isn't the converted M2T clips that are the problem, it is anything from the Sony HVR A1. Whether is has come from tape or the MRC1K, whether it is from MPEGstreamclip or via Premiere elements, it doesn't play on MediaPlayer 11.
However, if it came from the Canon XHa1, whether from tape or the MRC1K, it does play in MediaPlayer.
So now I'm really confused, and on the wrong board!!
Old April 30th, 2009, 10:59 PM   #3
Annie
Why don't you try and play the clips from your Sony HVR-A1 on another PC and see if you have the same problem; or the other way around, try another Sony HVR-A1 (if you can get the clips from your local store or a friend) on your PC and see, Just a thought.
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old May 9th, 2009, 02:08 PM   #4
Originally Posted by Stelios Christofides View Post
Annie
Stelios
Hello Annie,
I had comparable problems on my PC with XP a year ago, not only with m2t-files, but also with plain capturing. I bought a Mac Pro and all my problems belong to the past. Works flawlessly. Should have made the switch ages ago. Get rid of the PC asap.
Old May 20th, 2009, 08:33 AM   #5
I've managed to do some more experimenting, and everything works fine on my windows vista laptop, with apparently the same version of Mediaplayer.
I've now had the same problem with clips from the Canon XH-A1 that have been processed through Premiere elements 7 - they play on the laptop but not on the new desktop.
So it is the computer, and unless someone else has had the same problem and found a solution, I'm probably going to be stuck with it.
Old May 20th, 2009, 03:16 PM   #6
Problem now solved. A bit more research on these boards indicated that there was something called Media Player Classic that would work in situations where Windows MediaPlayer wouldn't. So I googled it, downloaded it, ran it, and hey presto, my clips now run the way they should!
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
