V1E interlaced vertical banding?
I've noticed that if you look hard at the output video, you can see very faint vertical grey lines over the entire frame. Only a few pixels apart and more obvious on colours like white and yellow, but does anyone else see this also? Is it just the CMOS capture? I'll post a pic shortly captured on memory stick... ( ie its not an output device problem)
Thanks - need to clarify is this is a fault or not..... |
