86mm narrow filter for v1?
further to my post re: 86 mm filter under sony wa lens hood. anyone found one thin enough?
leslie |
Leslie,
I have a Sunpak UV that fits just fine. Lee |
hi lee,
thanks for the reply, but i'm writing about the sony wide angle lens (86mm) - VCL-HG0862K, and i think it's an even smaller clearance.... leslie |
Just out of curiousity: is it possible to fit the VCL-HG0862K (which is Bayonet mount) on the V1 with an UV filter attached (as in the picture posted)?
yes, no problem. however, the hood wont fit over the filter...
ie. the sony wa does have a filter thread. leslie ps. sorry just re-read your question. i don't think so, and i'm not too sure of the practicality of using filters between lens' - the only time i've ever done that was years ago with my beta sp rigs when i'd stretch a piece of stocking over the back of the lens for that 'soft' look.... |
i work the other way around - i keep my wa on all the time, and only rarely take it off. hence my annoyance at the bad design aspect of sony's lens hood...
leslie |
And don't forget you're working at very short focal lengths indeed. With Sony's 0.8x wide-angle in place you're shooting at a focal length of about 4 mm. Hold your fingertips 4 mm apart and see how tiny this is.
So, best advice is not to use any filters at all unless it's absolutely unavoidable or unless you can very effectively hood or flag that front element. If you don't do this and shoot into the light, every speck of dust (on both sides of the filter and on your front element) will become glaringly obvious on screen. tom. |
very true tom - i've learnt the hard way in past.....
however, i would still feel much more comfortable with a filter on the front and the knowledge that i might have a dust problem, than not.... leslie |
1 Attachment(s)
A couple of weeks ago, somebody posted this picture of his rig - I'd be interested to know where a French flag like this could be found, and how it is mounted to the V1? Certainly looks good, and does the job!
Clever idea. Is that french flag being held in place with a strip of velcro?
I want one of those french flags. Where can I get one?
EDIT: OK, I found it; it was Brian Rhodes: http://www.dvinfo.net/conf/showpost....2&postcount=14 |
