Z1 + BR/Encore Question
Hello,
I'm trying to create a BR image in encore but wondering what is the maximum bit rate I should set for the standard 1440*1080 footage? Min Rate? Target Rate? Max Rate? |
BR Presets
Hi,
An Adobe tech I spoke to actually advises to first use the presets for BR and see how they work for you. Then and only then should you deviate from the suggested stream rate. |
2.1ghz Quad core 8gb Ram machine so I thought the rates might be too high? |
When I checked the Encore presets I found them to be lower than I expected (~15 Mbps), so I reconfigured everything to match or exceed standard HDV bit rates (e.g. 25 Mbps). Rendering shouldn't take 8 hours on your machine, so there must be a problem somewhere.
