Z1: Can I use Cineframe 25 over 24 for NTSC?
I'm sure this will require a conversion, but what if I were to shoot in Cineframe 25 (which has gotten more positive feedback) in PAL, then convert to NTSC in post? Would this not give a close to 24p look? Or would I just lose resolution? Would people notice the extra frame?
I'm sure someone has to have thought of this, and there's probably a problem in the conversion that would make it less than the best way to go, but it couldn't hurt to ask. Also someone mentioned that PAL has a better color pallette than NTSC. Would that be possible if one camera did both, as is the case with the Z1? |
Elliot, do a search, this is one of the most discussed issues on this board. I recommend a bit of reading and research.
Shortish answer(s)
Even short answer - people have been doing it for years... |
My apologies, chalk it up to newbieness, that was my first post. Thanks for the info, looks like that may not be the solution I'm looking for, not with a 4% slow down.
You can read all about this (Z1 25p to 24p conversion) at the CineForm web site. Shooting 25p and slowing down by 4% is done all the time to convert PAL to 24p. It is a lot better than using CineFrame24 alone unless you have Connect HD which will reverse telecine the Sony CineFrame24 back to 24p for you. Connect HD will also do the 4% slowdown from 25p to 24p for you as well. It’s a great tool to have if you want 24p out of your Z1 because you have both options available.
~jr |
