-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   I want to mount light on Z1 Handle (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/67975-i-want-mount-light-z1-handle.html)
Chris Gorman May 22nd, 2006 10:13 PM
I tried my Cool Lux U3 on cam light on the front shoe of my Z1U and find that it makes the cam too front heavy (light weights 10 oz.) So, I'm pondering whether to look for a new affordable lighter weight light & battery solution, or instead try finding a way to mount my Cool Lux light onto the handle of the Z1, hoping it will be better balanced in that position.
What kind of inexpensive light wt. bracket could I get to do this?
Paul Dhadialla May 23rd, 2006 12:08 PM
Hi Chris - that is what i'm doing too. Hard to mount any heavy light on the front.
You should get this:
http://www.bhphotovideo.com/bnh/cont...ughType=search
Paul
Chris Gorman May 23rd, 2006 03:36 PM
light bracket to fit handle
Thanks Paul, it looks good, but pricey. I'm comparing it to a couple other less expensive brackets on B&H site.
Tom Hardwick May 24th, 2006 01:12 AM
I mount my Sony 20-DW2 light (plus Lumiquest diffuser) on the Z1's shoe and find it most excellent. Uses the same NPF batteries, is small, light (!) and self-contained.
tom.
Chris Gorman May 24th, 2006 10:57 PM
mounting light on Z1
tom.
Tom, do you know how much your light w.diffuser & attached battery weighs? So far any light I look at weighs at least 10 oz + even when they call if light weight.
Tom Hardwick May 25th, 2006 12:38 AM
Just for you chris I've been to weigh the Sony lamp + big NPF-960 (75 mins with both filaments lit) battery + Lumiquest Mini SoftBox diffuser.
0.44kg. What's that in your pounds? Just under 1. Of course you can run it on much lighter 750 batteries to keep the weight down.
tom.
Chris Gorman May 25th, 2006 01:08 AM
light weight
Thanks Tom for taking the time to do that - I really appreciate it. Interesting you don't find that front heavy during handheld.
BTW, I also put my wireless on the front - if I had to put the light there it would be on one branch of my Y bracket with the light on the other branch. For now I'm going to continue to keep a lookout for a good bracket for the handle at a reasonable price. Then add a Bescor Li battery pack worn on my belt to replace or supplement my current big short run battery belt.
Tom Hardwick May 25th, 2006 01:27 AM
Although I've now moved on to a Z1 Chris, my kitted up VX2000 is shown here:
http://www.fortvir.net/gallery/tom-s...m/Tom_s_VX2000
Generally (for the least objectionable shadows) I like to have the video light on axis with the lens, so the Sennheiser mic attaches to the top of the hefty L bracket and the lamp takes its place.
OK it's getting weighty but I don't mind that, it's such an excellent run 'n' gun setup. I don't like the idea of umbilical cords to my waist as I need to MOVE, man!
tom.
Chris Gorman May 25th, 2006 02:57 AM
attaching things
Nice setup Tom on your VX2000. I used to attach both my light and shotgun mic on a Y bracket into camera shoe on my VX1000 (same essential body) and the total weight and weight distribution was still good. Wireless was taped to the handle, plugged into the Beechtek. But now on my Z1 with the shoe so very far to the front, it's a different story.
My U3 Light can adjust to tilt down. It achieves a good angle without being right in front of talent's eyes in situations where they might need to look into the lens.
Chris Gorman May 25th, 2006 10:28 PM
bracket stabilization
1 Attachment(s)
. . .excellent run 'n' gun setup.
tom.
Your run n' gun setup inspired me to again try attaching my "L" bracket to the bottom of my Z1. Problem is that without a stabilizing pin next to the screw, it gets loose during use. Does your Heavy Duty Bracket have any kind of pin to prevent it turning on the screw - you know, like the one on the camera plate to keep the camera from turning on the plate?
Tom Hardwick May 26th, 2006 01:50 AM
Know just what you mean Chris. I've no pin as you describe but have attached another little plate at right angles to the bottom of the 'L' and this buts up neatly to the base of the Z1, so stopping the L bracket from turning on its fixing into the Z1's tripod socket.
I tried to upload more pictures to that same fortvir site yesterday, but it was having none of it. Will try again in a few days when I've more time.
The L brack makes me so MUCH more stable. I did last Saturday's wedding without it 'just to see' and I felt I was wobbling all over the place.
tom.
Heath McKnight May 30th, 2006 09:39 PM
Best ever:
http://www.bebob.de/international/lux_eng.html
with this:
http://www.bebob.de/international/co...erter_eng.html
I wish I had that a few years back on my old XL1--the light was bright and had a seperate battery.
heath
Chris Gorman May 30th, 2006 11:40 PM
mounting light on z1
Thanks Heath -I looked at those links. It looks ok on the large camera they show, which is a shoulder mount, but I don't see how this would work on the Z1U which is not a shoulder mount camera and also has the shoe placed forward of the lens and it looks like that's where this light would attach. I can't imagine putting anything on the Z!U shoe other than the lightweight wireless receiver.
It seems a bracket for the handle might be the solution and the bracket suggested earlier in this topic at first looked pretty good (pricey), but now I realize that it would have the problem of the light turning on the screw mount.
Heath McKnight May 31st, 2006 12:09 AM
I've used the bebob with coco on a Z1. That's the only camera I've used it on.
hwm
Chris Gorman May 31st, 2006 01:32 AM
stabilizing L bracket
tom.
When you get a chance please explain more how you attached what kind of plate and where you got the necessary pieces. My L bracket screws to the bottom of the camera between the cam & tripod plate. I'm trying to imagine how a plate could be attached and have it fit both when it's on tripod or switching to monopod. I do like the added stability with an L bracket so it would be great if I could make it stable and even add my light.
