Cassette Tab Warning.
Save" tab on the cassette in the "Save" or "Record" .........this came up with an error code of CC:32.......
ANYONE ever have this displayed? I did move the tab on the cassette, but placed it back to the original position to finish using the end of the tape. Thanks, LOU |
Here's a list of error codes for Sony cameras. Hope it helps:
C 04 00 Non-standard battery is used. Use the info LITHIUM battery. C 21 00 Condensation. Remove the cassette, and insert it again after one hour. C 22 00 Video head is dirty. Clean with the optional cleaning cassette. C 31 10 LOAD direction. Loading does not complete within specified time Load the tape again, and perform operations from the beginning. C 31 11 UNLOAD direction. Loading does not complete within specified time Load the tape again, and perform operations from the beginning. C 31 20 T reel side tape slacking when unloading. Load the tape again, and perform operations from the beginning. C 31 21 Winding S reel fault when counting the rest of tape. Load the tape again, and perform operations from the beginning. C 31 22 T reel fault. Load the tape again, and perform operations from the beginning. C 31 23 S reel fault. Load the tape again, and perform operations from the beginning. C 31 24 T reel fault. Load the tape again, and perform operations from the beginning. C 31 30 FG fault when starting capstan. Load the tape again, and perform operations from the beginning. C 31 40 FG fault when starting drum. Load the tape again, and perform operations from the beginning. C 31 42 FG fault during normal drum operations. Load the tape again, and perform operations from the beginning. C 32 20 T reel side tape slacking when unloading. Remove the battery or power cable, connect, and perform operations from the beginning. C 32 21 Winding S reel fault when counting the rest of tape. Remove the battery or power cable, connect, and perform operations from the beginning. C 32 22 T reel fault. Remove the battery or power cable, connect, and perform operations from the beginning. C 32 23 S reel fault. Remove the battery or power cable, connect, and perform operations from the beginning. C 32 24 T reel fault. Remove the battery or power cable, connect, and perform operations from the beginning. C 32 30 FG fault when starting capstan. Remove the battery or power cable, connect, and perform operations from the beginning. C 32 40 FG fault when starting drum Remove the battery or power cable, connect, and perform operations from the beginning. C 32 42 FG fault during normal drum operations Remove the battery or power cable, connect, and perform operations from the beginning. E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor |
Thanks for the reply.
I did an extensive GOOGLE search and found out the problem is found in many SONY cameras. I was able to fix same via the troubleshooting manual BUT it this fails, the user has to slap the camera a few times and it will return to normal. YEP......slap the camera. Just put in CC:31 in Google and there is an entire forum thread relating to slapping the camera. Go figure this one out. |
