Accessories for Z1
I have just bought my Z1 and I am making my accessory shopping list. Besides the essentials, like filters, extra batteries, etc., I am considering getting the following:
1) LED small light head. What affordable LED lights are around that have performed good service? The ones I have seen around are a bit on the expensive side, and I have also considered a DIY project for this. The job it should perform would be filling light or eye light, so it should have some way to attenuate it. 2) LCD screen support. I have a 7" LCD which I would like to use with the Z1. The question is how to secure it when the camera is a on tripod. What has worked fine for such application? 3) Cokin products. Cokin makes filters and an extendable bellows that I think can be used on the Z1. Cokin filters are rectangular and can be fitted in the filter holder on the back of that bellows. Is anyone using or has anyone used any of these? Carlos |
Hi Carlos
I have a Z1 with the following bits.. that make shooting easier and better: TLS Matte box... (similar to Formatt) Schneider filters..Polarizer/ND/Blackmist Cavison shoulder mount AT897/Rode NTG-2 mics Sennheiser radio mic Petrol LCD hood PAG ligth C6 kit Lowell video kit..rifa/tota/spot Regards Gareth |
Hi Gareth,
I don't think you will find a lot of need for an LCD hood on the Z1. The transreflective screen is very vivid under full sunlight. I tried my PDX-10 LCD hood on the Z1 once and wasn't happy with the fit since it's really designed for a different sized 4:3 screen, but I suppose it would work in a pinch...
I use the Z1 with the Cavision shoulder brace, using the LCD with hood as my viewfinder...this way the camera is more compact and sits better on the shoulder.... Although the LCD is bright in day light I do find the Petrol hood useful for shading the screen however in bright sun..... before getting the hood I used to wear a peaked baseball cap to shield my eyes and the screen.. regards Gareth |
Personally I have never felt a need for an LCD hood on my Z1 however. |
I am researching adapting something like this: http://www.ledtronics.com/DS/GDL002-200/default.asp Or use a lamp such as this: http://www.ledtronics.com/ds/B640/ Particularly the latter might turn out something cheap and practical. In both cases, lumens output vs watts used is incredible. Or perhaps something simpler like this: http://store.sundancesolarcorp.com/12vdcclliwi1.html I think you must be getting what I am after. A very affordable and bright battery powered system. Carlos |
1 Attachment(s)
FWIW, Sony showed their own LED light at the V1 press conference. No idea what the cost or availability is, but it uses the same batteries as the Z1.
Boyd's right - the top screen works fine in direct sunlight - wonderful. It's best to get familliar with the zebra settings you choose and their effect on exposure, but you really don't need a Hoodman any more.
Beware any Cokin filter as none of them are coated. You'd not have bought the Z1 if Sony advertised it as having an uncoated front element, would you? Same goes for the Tiffen filters I've seen, but I assume you can order fully multi-coated ones as well. At the sort of focal lengths we're dealing with (4,5 mm) be very sure you need to filter up front rather than in post. tom. |
got a great shoulder bracket from cavision, the camera mounts on the rods to the left side of the bracket meaning you can actually use the viewfinder without cocking your head too far to the the right!
