Diffusion filter Tiffen Pro Mist 1/4, I look for info
Hi,
I'd like to ask some question please. I am purchasing Sony FX7 to make documentaries around the world but Century Optics doesn't have any Wide Angle Lens yet. I hope Y donět make a mistake. Do you know when Century Optics will ship with a Wide Angle Lens for FX7? A last question: I am undecided between an UV filter or a diffusion filter Tiffen Pro Mist 1/4. Do you know that filter? In your opinion can I use it permanently on FX7 camera as a UV filter? Thanks for your suggestions, |
About the filter, you shouldn't leave any diffusion filter on your FX7 all the time. If you don't want to use an UV, which should be your most neutral option, I'd suggest to get a graduated ND, which should rotate and help you tame brighter areas in your frame, like the sky. |
