CinemaTone? Do you use it?
I own a Z7u and just purchased an FX-1000. I was curious as to how many of you adjust these settings in the camera or do it in post? I like the option of doing my color correcting/adjusting later. Are there any benefits to doing it in camera vs. later?
I have just started to experment with the picture profiles so I don't have a lot of knowledge in this area. A couple of days ago I shot video of a friend driving his truck. I used cinematone 1 (I think) because it is my understanding that it cuts down the dynamic range of the scene. In the past when I have done this, if the driver was exposed well then the background sky was completly blown out. If you don't see any detail in the sky then it is hard to put it back in during post. With the cinematone profile selected, I could get a good exposure on the face and I could still easily see the coulds. So I think there is something there to be gained that cannot come out of post.
I'm a firm believer in doing what you can in camera. You just have to make sure that's the look you want, going back can be a pain or impossible to do. In a controlled environment yes.....run and gun....never.
Cinematone 1, used with black compress, gives a look I like....in good lighting. |
I would think Cinema Tone would be especially effective for the getting ready footage, unless the room has dark or very warm look to begin with. If the venue is relatively cool then the Cinema Tone would be especially nice.
I have used it once but the background had a very rich, warm look to begin with and it was too much. |
2 Attachment(s)
Here's two frame grabs you can compare. I think the resolution was reduced when they were uploaded. You can really see a difference in full resolution.
The one that says on is cinematone 1, black compress on. |
Wow Tim, the black compress really helped the black in your photo. Nice. I use that setting also.
Greg, thanks for the message about the shoe adapter! |
Tim,
I agree with your No to "Run and Gun". Each Bridal Prep is so different that I think my "washed out" standard look is better. Correcting in post is going to be the safer method for me. Can these presets be saved/swapped from camera to camera on the Sony Z7u? My old Canon XHA1 had lots of user created profiles that I pulled from this forum. -Chad |
Good question Chad. I'd like to start a section for FX1000 saved setting files... like they have for the xh-a1. There is a large archive of presets.
That would be good!
Actually he gave me a link to b&h for a NRG adapter. NRG | 59111 Accessory Tri-Mount | 59111 | B&H Photo Video
That's great I found several other much more compact adapters as well. Below is one that fits in the mike holder.
thej-rod.com |
