February 11th, 2009, 10:28 AM | #16 |
Tim, is your model with a plastic or metal gimbal?
February 11th, 2009, 10:33 AM | #17 |
Ok...gotcha Ethan. But I'll tell ya, if you add any more weight to that rig you will definitely want the vest, or use it in very short spurts.
Tim |
February 11th, 2009, 10:35 AM | #18 |
I think it's plastic Jeff, but I'll look when I get home and let you know for sure.
Tim |
February 11th, 2009, 10:48 AM | #19 | |
I'll look forward to your reply about the metal vs plastic. Thanks for your helpfulness, Tim. |
February 11th, 2009, 12:25 PM | #20 |
It is my understanding the Merlin with a metal gimbal will hold up to 7 pounds. Double check that first before you start throwing weight at it!
I've used my Z1 with a big, thick battery on it with no issue. However, my forearms aren't like Popeye's so I recently bought a HV30 specifically for the Merlin. Whew! |
February 11th, 2009, 01:18 PM | #21 | |
I've found that smaller cameras are harder to control and tend to get a little more finicky than the larger cams. Your take?
∅ -Ethan Cooper |
February 11th, 2009, 03:15 PM | #22 |
Blake I was thinking the same thing about getting an HV30 for use with the merlin. It would be a killer combination in a well lit environment, but Ethan puts a damper on that idea!
February 11th, 2009, 03:42 PM | #23 | |
I'm also a pessimist and tend to put a damper on most ideas.
∅ -Ethan Cooper |
February 11th, 2009, 04:00 PM | #24 |
I know that my heavier FX1000 is much better on tripod than my old 2100, the added weight really makes a difference.
February 11th, 2009, 04:14 PM | #25 | |
Compact flash
I'll back that up Jeff. That was the first thing I really liked about the 1000/Z5 was it's just beautiful on the tripod. Seems weighted nicer than TRV900/VX2000 and Z1 on the legs. Hey I had a mate in yesterday and showed him just how quickly my old TRV900 goes in and out of rec/pause back into record. He was blown away. This is just something I am going to have to accept with the FX. I guess all cameras have their pitfalls and one has to just work around any issues but gee I still can't get over seeing a shot and not being able to record it. Should have waited for a Z5 as I understand recording to the Compact Flash unit gets around this problem. I think I read this correctly on a post a week or so ago. If this is correct this therefore would mean that one would be recording more footage to Flash card and less to tape because recording to tape has the 2-4 second delay when doing a quick rec/pause/rec sequence. Hope that makes sense. Can anyone out there back that theory up? |
February 11th, 2009, 05:13 PM | #26 |
It's plastic Jeff.
There's a Z1U with a 970 listed in the Merlin cookbook which gives the weight as 5.2lbs. Here's the link: Welcome to Tiffen - Steadicam Merlin Cookbook Settings Panasonic HVX-200 5.4lbs here: http://www.merlincookbook.com/user.php
Tim Last edited by Tim Akin; February 11th, 2009 at 05:16 PM. Reason: added link |
February 11th, 2009, 05:39 PM | #27 | |
As far as the theory that you'd be able to record more to flash by eliminating the delay, it does make sense. The Reader is really the major point for me going with the Z5 over the 1000. I think Sony really dropped the ball by not having external device control on the FX1000, but then again they may have thought that omission would sell more Z5s. |
February 11th, 2009, 05:54 PM | #28 |
Martin, I have regretted on more than one occasion I didn't hold out for a Z5. I was in a hurry and bought what I could afford at the time.
The advantages are too numerous. The FX1000 will work out fine, but my third cam will be a pro model, whether it be a Z1 or Z5. |
February 11th, 2009, 06:02 PM | #29 |
Sounds like a good excuse to get or use the gym membership. Who says being a videographer won't get you in shape! :-)
February 11th, 2009, 06:06 PM | #30 | |
I have read that the FX1000 and the Z5 are in the same scenerio. Yes there are features on the Z5 that aren't on the FX1000 but from a visual perspective, those two should mate perfectly in a 2 camera shoot. So when considering your 2nd cam, I'd forget about a Z1 and go straight to the Z5... Jon |
