help!!can i get uncompress video out of z7 ?
i currently own the z7.everything work fine but th enext coming project i need to do a bit of keying.so i wonder can i get uncompress signal(4:2:2) come out of z7 through hdmi or component for better keying work ?
Hi Danny - you can't. Z7 is MPEG-2, giving you a 4:2:0 color space in HDV.
hmm so it will same with v1 ?
Same with any HDV camera.
so i tmean all the ingal com though hdmi and componet is after the hdv compression....
I'm sure you can get uncompressed from the HDMI, look at products from Convergent Designs. The Flash XDR hooks up to the HDSDI and they do a HDMI to HDSDI converter I think. Also, does their XDR Nano take feed from HDMI?
Steve |
answer
I have tried to capture full HD via HDMI on my DECLINK intensity card, and it works just fine. Picture quality is perfect, and very usable....... So, U can get a great key results...... |
Yes. The key component being that you have to be capturing the signal live and via HDMI (not firewire).
If you have already recorded to tape, then you've already chosen to compress the signal using MPEG-2. The Convergent products will be great if you want to capture live into a higher quality codec and preserving 4:2:2. Both will require HDMI to HD-SDI converters, and only the XDR allows you to record uncompressed. The Blackmagic products work fine too, you just need to be near a PC. And the Matrox MX02 will be great, so long as you have a MacBook Pro or Mac Pro, though the MacBook Pro may not have the hardware requirements to record uncompressed. You may need to choose another high quality codec. Myself I wouldn't even both recording uncompressed. There's many high quality 4:2:2 codecs that are pretty close to uncompressed, such that visually I don't think many could tell the difference. I know I probably couldn't tell the difference between a 100mbps MPEG-2 recording at 4:2:2 compared to a completely uncompressed signal. |
i did try to capture from z7 to my mac pro thought hdmi and componen.the footage look to gainy event i got gain set to -6.and it seem like it go through hdv compression.i will try to test again with both shooting to tape and to computer and try to c the different between them 2.
what i did was i conect my camera to my macpro with hdmi cable then go to log and capture in fcp and use capture now to capture what ever come out from z7 !!is it live capture ?
