help - un-readable transcend card at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old July 15th, 2009, 11:57 AM   #1
Greetings folks
I have a Transcend 16GB that is un-readable by either my camera, a mac or a PC -
have used this 3x I think
any suggestions?
I can't seem to get anything to read it so I can't re-format...
the error I get from the camera is A:19:91
in the manual it says
"The CompactFlash you are using is not recognized. Check the type you are using."
thanks
Jamie
www.lostwax.org - Multimedia Dance Theater
Jamie Jewett is offline   Reply With Quote
Old July 15th, 2009, 12:15 PM   #2
I have had this fault too when I had a card that was formatted on the mac, have you tried re-formatting it in the camera recorder.
That seemed to cure the fault I had, as a side note you should always format the cards in the camera and before each use.
Old July 15th, 2009, 12:56 PM   #3
how to re-format if unreadable?
Thanks Gary
but how do I reformat in the camera if it's unreadable?
thanks again
jamie
Old July 15th, 2009, 02:17 PM   #4
There is a known issue with Transcend CF x133 cards and Macs. When you eject the card from the Mac the card can be permanently damaged. Transcend say they have fixed this on new cards but many older cards can be damaged by Mac's.
Old July 15th, 2009, 02:28 PM   #5
That's right. I had the same problem with two Transcend cards.
Old July 15th, 2009, 02:30 PM   #6
ahhhh - thanks
well then - that might just explain it -
any idea what newer or older might mean?
I bought this in April...
thanks again
Jamie
Old July 15th, 2009, 03:09 PM   #7
thanks again
Jamie
I had the same problem with one bought in April, the replacement in early May was the same, the second replacement in June is fine :). Neither had been near a Mac by the way.
Hedley Wright is offline   Reply With Quote
Old July 15th, 2009, 04:05 PM   #8
19:91 means the card is toast. I had one like that a couple months ago.
Bruce
Bruce G. Cleveland is offline   Reply With Quote
Old July 15th, 2009, 06:32 PM   #9
Bruce
Check to see if is under warranty.
Keith Forman is offline   Reply With Quote
Old July 16th, 2009, 02:35 AM   #10
When I had this the error massage came up on the card recorder on the camera but when I pressed the menu buttons I could still get into the menu to format it.
Old July 17th, 2009, 04:24 PM   #11
This link to a previous thread may be of some help: http://www.dvinfo.net/conf/convergen...eopard-os.html
/ Battle Vaughan/miamiherald.com video team
Old July 18th, 2009, 03:00 AM   #12
Tried all this, but to no avail: even in the 'disk utility' app, the card in the Lexar reader is not recongnized! Ergo the 'erase' button is never highlighted and there's no way to access the card. What now?
Old August 12th, 2009, 06:02 AM   #13
No ideas, anyone???
Old August 15th, 2009, 09:05 AM   #14
No ideas, anyone???
do you get any error when you put the card in the recorder? I had a couple cards that the recorder wouldn't recognize and it gave an error, but I just hit the 'Stop' button (or maybe it was the 'Menu' button) on the recorder and the regular menu came up and I was then able to format the cards with the recorder. You might be lucky.
Darryl Yee is offline   Reply With Quote
Old August 21st, 2009, 06:13 AM   #15
Thanks for the advice, but I already tried that and I keep getting the message: "error: A: 19: 91" and none of the buttons on the recorder is working
Luc De Wandel is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
