Z7 with Alpha Adapter?
If I get an alpha adapter for my Z7, will it give me the same shallow DOF as a 35mm adapter like the Letus? I mean, isn't the whole point of those adapters to put on a photography lens? And if so, can someone upload a test with the Z7 and the Alpha converter for me to see how it looks? Ohh, and I heard that if you use this adapter it shoots only in 4:3 not 16:9, is this true? Thanks.
Hi Michael.
Unfortunately, you will not get shallower DOF by using this type of adaptor because the format is too small. However, there will be a magnification of the image by 7.2X. Take a look at some of my customers clips, particularly those of Massimo Uberti. Shot with a Z7 and Nikon lenses (using our adaptor) Video Clips I hope this helps. Cheers |
Michael, I think nearly everything you stated is wrong. Pleas take this as constructive criticism.
First off please read the difference between DOF & FOV Depth of field - Wikipedia, the free encyclopedia Field of view - Wikipedia, the free encyclopedia Quote:
A Letus will give you the save FOV (field of view) as a 35mm still camera. Quote:
(If you put a 52.8mm SLR lens on the Z7 you will get the exact same DOF & FOV as when you have the stock lens zoomed in all the way. If you want the same FOV that a 52.8mm lens produces on a 35mm SLR camera on your Z7, then you'll need a Letus or Redrock.) Quote:
The SLR lenses you'll be using are designed to be used on cameras with much larger chips than the Z7, so the image passing through the SLR lens will be much bigger than the CMOS chips & will cause you no worry that you'd have to shoot 4:3 & crop off the corners of the chips. |
