Dual record
Can anyone verify that the dual record will allow Standard definition on cards and hd or standard definition on internal memory?
Or can it only record hd on both? I need to have standard def on the card and a backup on the internal memory. Thanks |
Re: Dual record
Hi Robert,
This is something I'd not considered before, as I never shoot SD. So I had a look. It really seems to me as if you can't do simultaneous recording to both card and internal memory as SD. "Simul Rec" on the Rec/Media Set menu has an HD icon beside it. That implies that it is for HD only. When I set the camera to SD, the Simul Rec option grays out. So it seems as if you can only record to internal OR memory card when recording SD. Which seems a bit mean. |
