video new guy with a NX5
I have just entered the Video world. I have been a still Photographer for years and I am having difficulty with the Language. The Manual that came with the Sony NX5 is written for a seasoned Videographer. Hopefully some of you people can give me a hand.
What is the Gain all about and where should it be set? I believe the Auto switch sets the camera to all auto functions such as white balance, shutter speed, and f stop? I Am I right in thinking this? I have the quality set to 1080/60 pi is this the best quality. Thanks in advance and I am sure I will be back with more questions. |
Re: video new guy with a NX5
The first number represents the frame size: 1080 is 1920x1080 and 720 is 1280x720. The second number is how often the picture is updated. (I'm avoiding the term "frame rate" here). Now the tricky bit. the letter "p" means progressive and "i", interlaced. This might help: http://www.dummies.com/how-to/conten...g-methods.html If your output is for the web, then stick to progressive, if for DVD, then interlaced. |
When it comes to exposure tradeoffs, you now also have to think about the ND filter, which is far more important on such a small sensor.
Diffraction will start to affect the picture sharpness at about f5.6 on an NX5, so you will need to add ND if you need to stop down below that. I'm not familiar with the operation of the NX5, but I expect if will warn you if you need to change the ND setting. |
Yes it warns you if you need the ND. I try not to go more than F4 for sharp image. Focus control is separate. One other thing to note. Just putting the switch to manual does not put ANY of the parameters in manual !! You need to set each individually and if you do not do that the camera is still in auto using the parameter that has not been set, as the control . In other words if you put switch in manual and then press gain and set one of the switches it will still have shutter speed and iris in auto. If you set shutter speed and gain in manual then iris will be in auto until you press iris and manual set the iris ---then you will be in full manual. This is indicated in the LCD so take note when you shoot that you are in the mode you want to be in !!! Pressing any of the parameter buttons while in manual will return that control to auto leaving the others in manual. I often preset AE shift or spotlight ( I have them assigned to buttons) so that I can then press, gain usually, and let the camera control, offset by either spotlight or AE shift if things get a little out of hand for me !!! You can see on the LCD what is happening and switch between as needed.
Ron Evans |
Thanks guys, I am adjusting to the new world.
RE: I believe the Auto switch sets the camera to all auto functions such as white balance, shutter speed, and f stop? I Am I right in thinking this?
FYI. setting the switch to manual is not the same as M mode on a still camera.. all of the variables are still automatic unless you individually set them to manual. eg. set switch to manual and toggle the white balance switch to manual. you can then perform a manual white balance against a known white card or object using the white balance detect button against position A or B. Your Gain, Aperture, Shutter, etc will be still be AUTO |
Auto sets exposure controls to auto or when set to manual allows the controls to be set manually. It doesn't set them in manual only allows them to be set with their controls. If one just moves the switch to manual then the camera is still in full auto. Focus has its own controls
Ron Evans |
I'm not sure why someone suggested putting the gain at 0, I keep it at -6. The lower the better.
Ron Evans |
