NEX-FS100P or NEX-FS100E & kit lens
Hi can anyone please tell me if there is any difference between these two:
Sony NEX-FS100P & Sony NEX-FS100E Moving to europe in a few months, but buying the cam here in Asia. The store has both, and the info about them seems to be the same, but they are different models in some way. By the way, I also read the last thread regarding lens options, and someone post this one which is too cheap to be good. But is it better than the kit lense? Sony SAL-2875 28-75mm f/2.8 SAM Constant Aperture Zoom Lens SAL2875 : Zoom : A-mount DSLR Lens : Sony Singapore Any other suggestion for a lens that is less than 2k but better than the kit lens? I heard that is a nightmare to operate manually. Thanks for the help!!! Cheers, Martin |
Re: NEX-FS100P or NEX-FS100E & kit lens
Deleted. Changed my mind.
You will need a LA-EA1 adapter for the SAL-2875 or any other Sony Alpha lens: LA-EA1 : Shooting : E-mount Accessories : Sony Singapore There are several good Sony Alpha still lenses out there for less than 2k -- but they are all still lenses, and not optimized for video or motion pictures. A purpose-built motion picture lens with a native or adapted E mount will cost significantly more money. |
"Any other suggestion for a lens that is less than 2k but better than the kit lens? I heard that is a nightmare to operate manually."
YES THE 18200 IS HORRIBLE! If you want an E-mount, go with the 1855. Yes, it is slow and short, but it is butter sweet and gives you ALL the automation the NEX camera's can provide. (By the way the 1855 is not too slow on the 800ISO FS100.) If you want to go this way: buy a highly discounted NEX-3 with 16mm and 1855 bundle. Then sell the NEX-3. Expect slow-AF if you use Sony adaptor with any A-mount. Slo means 5 to 10 seconds to lock on a static subject. AF on a moving subject while shooting -- doubt it. The Sony adaptor transmits data too slowly for video work and will be replaced at some point. |
I'm looking at the Sony 28-75mm 2.8 zoom. I have the a-mount adapter, so it'll go right on my VG10, and maybe an FS100 in the future.
I just want the 2.8 f stop. Or maybe a good 50mm prime. As far as the 18-200: I own a VG10 and have never owned a DSLR, so this is my first experience with a DSLR zoom. As such, I can't compare it to other DSLR lenses. But compared to video zooms, well, the 18-200 isn't one. The zoom and focus controls are placed in a different order compared to a video zoom. The zoom is infinite, whch means it keeps going around and around until you hit the focus point. It's easy to spin right past your focus, so you have to keep adjusting it bit by bit. In a large sensor camera, this is crucial. The zoom feature is good enough, but bear in mind, DSLR zooms aren't meant to zoom during a take like video zooms. The lens won't hold a focus; you have to re-focus every time you move the zoom level. Look at the lens more as an infinte prime, instead of a video zoom: you set your shot, focus, and you're good to go. Widen or tighten your zoom, then you have to re-focus. For indoor use, it's a slow lens. 3.5 f-stop at its widest setting isn't really good. But at least on the VG10, the camera is good for a very high, very clean gain level. Of course, that kind of defeats the purpose of a large sensor camera, to have more control over depth of field. |
The FS100E is a 25fps/50fps only version, The FS100U is the USA 24/30/60fps model, the FS100P is the Asia pacific model, 25/50fps, FS100N is the Latin America version, 24,30, 60fps, FS100C China version 25/50fps. Add an extra K after the above for the "kit" with the 18-200mm lens.
Hi,
Somewhere (i think that) i was read that an update firmware will allow the Pal version to record or output at 24p. Does anyone knows anything about ? |
Already ordered. It seems that the Pacific version and European version are exactly the same then. And I'm glad that I decided to order it without the kit lens.
Thanks. |
There is a strong rumour from Sony that there will be a future firmware update that may allow for alternate frame rates on the FS100, however it is possible that this might be a paid-for update.
By the way, any suggestion on rig/follow focus for the FS100? Under usd 2000 if possible
thx! |
