-   Sony NXCAM NEX-FS100 CineAlta (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/)
-   -   fs 100 jk (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/519184-fs-100-jk.html)
John Beattie September 27th, 2013 09:35 PM
fs 100 jk
Anyone know if the Sony NEX-FS100JK form Japan is the same as the US model? Can I use one from Japan here in the US without any problem? Not sure if the Japanese video is compatible with our TV's computers etc or not..
Paul Wood September 28th, 2013 05:08 AM
Re: fs 100 jk
Hi John,
I think with the software update, it becomes a world cam - below an excerpt from the Sony Software update instructions:
[50i]
1080/50p PS 1080/50i FX 1080/50i FH 1080/50i HQ 1080/50i LP 1080/25p FX 1080/25p FH -720/50p FX 720/50p FH
* NEX-FS100U/FS100N/FS100UK/FS100NK ** NEX-FS100E/FS100P/FS100EK/FS100PK
When you change the setting, the camcorder
will turn off and then on again automatically.
When any recording media is formatted or recorded with the [60i] setting, you cannot
record on or play from that media with the PAL system. When any recording media is formatted or recorded with the [50i] setting, you cannot record on or play from that media with the NTSC system. If the [A movie with a different video signal format from this device has been recorded. Movie recording disabled.] message appears when you switch the setting between [60i] and [50i], use another recording medium or select [MEDIA FORMAT].
If you select [MEDIA FORMAT], the protected movies are also deleted.
When you select [50i], [TC FORMAT] is set to [NDF] automatically.
