#16 | |
Re: S&Q questions
So for Slow motion are you guys using the 1080/50p or 1080/25p setting in S&Q and what is the reasoning behind the option you are using? Does the 1080/50p setting in S&Q give you better quality footage or is the extra recording bit rate just used to carry the audio track? |
#17 |
Re: S&Q questions
This behavior is normal, and exactly what Slow Motion (or "overcranking") is about:
- you shoot what is intended to be 1080/25p (at 25 fps), but recording 50 fps. Then, on playback (25 fps), you're getting 2x slower motion (and no audio). The 1080/50p mode on the FS100 has nothing to do with S&Q; it's a recording format on its own and can carry audio track, as well. Of course you can slow it down in post, but that's another thing to on-camera slow motion recording. Hope this helps Piotr
Gear: Sony EX1 w/ Letus Elite, FS100 w/ NanoFlash, Canon FD vintage glass, SCS Vegas Pro Specialty: live classical music events - www.castellogt.pl |
#18 |
Re: S&Q questions
Ok, I'm going to take a stab at this one. Hopefully I understand correctly.
There are 2 settings that you set, in S&Q. One is for your playback frame rate. For me, that is usually 24p or 30p. But it could be 60p, if I want super quick motion. So once i set my "conform to" rate, then I choose the frame rate for desired effect. If I'm conforming to 30p, and I choose 60p, I'll get 1/2 speed playback. If I record a frame rate at less then 30p, and then conform to 30p, I'll get quick motion. But your example of choosing 50p as your conform to frame rate, then trying to do 50p S&Q, basically all you are doing is recording normal video. That's why you'd get audio upon play back. When recording 1 rate (60p for me), and playing back at another (30p for me), you get no audio, because the audio would be a slowed down version of the actual recorded audio. Hope that makes sense. |
#19 |
Re: S&Q questions
Everyone is making sense, but that is not really what I'm asking.
You can use 50p/60p using 1/100 or 1/120 shutter and conform to 24p/25p/30p in Cinema Tools (Mac) to get slowmo from the 50p/60p setting (this is what everyone has been doing with 720/50p & 720/60p on HDSLR's to get slowmo). The added bonus with this on the FS100 is that you maintain an audio track which you can strip out before conforming and therefore retain audio at normal speed if required. In many reviewers opinions this was a big plus when shooting slowmo on the FS100. While this is a more involved workflow than using the 1080/25p or 1080/30p FX/FH settings I was wondering if there was actually any difference in quality between the 24mbps 24p/25p/30p and 28mbps 50p/60p settings hence asking what everyone was using. Perhaps I didn't explain myself very well, but thanks for the input! |
