FS700 lens support?
I am looking for some way to support long, heavy Canon lenses (200mm and 400 mm) on the FS700.
I don't want all that weight hanging on the front of the lens adapter. Anyone know of a system to do this? |
Re: FS700 lens support?
I just bought this shape lens support to use with my 15mm rods with the movcam rig.
http://www.bhphotovideo.com/c/product/750896-REG/Shape_wlb_LENSSUP1_Lens_Support.html |
Thanks for the suggestion, but I am really looking for something more substantial.
I am looking for a support system where I can attach the foot of tripod mount ring that comes with each lens. |
This one indicates it is specifically for dSLR lenses with tripod mounts.
http://www.bhphotovideo.com/c/product/739108-REG/Chrosziel_AC_401_33_AC_401_33_HDSLR_Universal_Lens.html |
I think what you were invisaging was this?
Support bridge for SLR lenses But it looks a little less macho than the one at B&H. The tripod support under big lenses like the Canon 80-200/2.8 are there to attach to a tripod, where the lighter camera body attaches to the lens. You could do the same, but the FS700 has enough mass to lead me to suspect that approach is a 'swings and roundabouts' situation. This is a more studly version of the previous item: Other Accessories : Lens Support Bracket As you can see, it's designed to hold the lens further away from the joint, thus - through the magic of leverage - it can support more with less, though you do have to pick your contact point carefully. A bigger issue is if you were putting a Broadcast ENG lens onto an FS100 - yes, it can be done: B4 2/3" to Sony E mount adaptor package That's probably the studliest mount I've seen, but maybe OTT for a 80-200/2.8. I tried Alister Chapman's FS100 ENG rig out. His 18x 8mm becomes a 24-432 (and that's 38-691mm in 35mm FF terms); buttery focus, excellent zoom range, but no image stabilisation and the Power Zoom needs to be fed off a V-lock D-Tap. |
http://www.bhphotovideo.com/c/product/665488-REG/Zacuto_Z_1_4_LS2_5_1_4_20_Lens_Support.html This will actually connect to the tripod plate mounting block on the canon zooms p |
Do you have a link to this?
If you're asking me, click on the description, it'll link you to b&h
I am just making a prototype for this very purpose, I will post photos here soon. I should have anodized production kits ready by the ends of this week.
I have had a few special requests for this, so I am working on it. Canon has a few different spacings on their "feet", so it has to be flexible. I will post progress here soon. |
I picked up one of these and it's been fine. I especially liked the 3/8" tapped hole on the base:
Long Telescope Lens Support Mount for HDDSLR 15mm Rod Rail System | eBay Also, on a related note, can anybody here say if the lens mount assembly of the '700 looks to be any sturdier and less prone to flexing than the one on the FS100? |
Here is another pretty good product at the comfortable price of $43
TILTA LENS SUPPORTER LS-T03 [LS-T03] - $43.00 : ProPhotographyGear.COM! |
