Mac won't see 50p and Timelapse clips from FS700
Hi ya all my first time here so thanks for everyone who helps out here.
I just got a 700 and like you all just love it, i film tourism and love that i can change lenses, travel between NTSC and Pal, Slo mo of course which is great for my waterfall , bees on flowers and also aerial shots as it smooths things out in bouncy choppers as i use a cattle chopper which is small, but more motion then the bigger Bell,s etc. You see if i use super slo mo at any speed it is seen by my macro tower no worries, ....but if i use the s&q at 50p they are not seen i.e.: all other clips show up on import with final cut x or iMovie but not the 50p or timelapse clips. I tried importing from the SD10 cards also from the FMU but no luck there. Could it be the computers problem it,s details are 2 by 2.8 Ghz Quad core, 14 GB 800 Mhz DDR2 FB DIMM, ATI Radeon HD 5770 1024 MB, Lion 10.7.5 Thanks for your input and great to be on the forum, Nevill the Devill. |
re: Mac won't see 50p and Timelapse clips from FS700
All speeds and framerates seen on PC with Sony Vegas software here so maybe it's a Mac thing, codecs maybe?
Chris Young CYV Productions Sydney |
No problem here with S&Q clips on an of my Mac's using Premiere CS6.
You might like ClipWrap: ClipWrap: Easy AVCHD and HDV conversion for the Mac
OTOH, you may wish to upgrade FCPX to the latest version. I've had no problem with S&Q and 50p with 10.0.6 and up (currently on 10.0.7). |
Hi Matt thanks for your help i updated both my op system and also to the latest FCPX but no luck , Yet. I movie won,t see those clips either. Thanks for the tip on Clipstar but my problem is i can,t even get the clips to be seen by my computer so it,s not a reading problem but a seeing problem. I can live without 50p if needed but it would be good for chopper work and timelapse would be nice rather then filming for 60 mins etc then playing in fast forward.
Still no solutions for this problem any more help?
No idea why your not seeing the clips, the vast majority have no problems so it's probably an issue with the way your system is set up.
Yes Allister that crossed my mind, settings on the camera you mean I guess or on the computer.
Re: Mac won't see 50p and Timelapse clips from FS700
