F1.4 E-mount?
There are a few F1.4 fast lenses in A-mount, but the problem is they would need to be used manually as the LAe2 adapter is needed to add a-mount lenses to the FS700. The LEA2 reverts the camera aperture to F3.5 in auto mode, these negating the low light capabilities of faster lenses.
So does anyone make a 50mm F1.4 E-mount? |
Re: F1.4 E-mount?
There is a convenient table of lenses on Wikipedia. No f/1.4 50mm listed. It looks like 1.8 is as fast as it gets in native e-mount right now.
List of Sony E-mount lenses - Wikipedia, the free encyclopedia |
Re: F1.4 E-mount?
I had a Sony 50mm F1.8 and the AF really struggled to focus so I ended up using it in manual so imagine how little DOF one would have at F1.4!! That's why they probably never made one ...Manual isn't that hard if you realise what DOF you have to play with and focus peaking (yes it works with a manual lens too) is a huge asset ... For me I would rather go a little wide to say 35mm as your DOF gets a wee bit more.
My go to lens at wedding receptions is a Sigma 18-35 F1.8 zoom and it almost sees in the dark!! Chris |
Re: F1.4 E-mount?
Thanks for the link.
I know that sigma Art lens is quite well regarded, but if go that route, I would have to manually focus. Simga has a 1.4 in an Art lens in an A-mount, but as a full frame lens I think it would end up being the equivalent of a 75mm with the Sony FS700's super 35mm sensor. |
Re: F1.4 E-mount?
if the sigma you referenced were in an e-mount, would it autofocus on a fs700? thanks in advance. be well. rob smalltalk productions/nyc |
Re: F1.4 E-mount?
Hi Rob
I guess it would but any fast lens and a big sensor is often not a good idea for auto focus ! Mine is actually a Nikon mount so I use a dumb adapter and I prefer getting focus right. Using the SEL18200F3.5 at weddings I often used to come home and find fuzzy footage at wedding receptions while interviewing guests and found that the AF often struggled when wide open. If you are considering the Sigma for it shallow DOF in good light then I'm sure the AF would work ..I had a Sigma 19mm and 35mm (both primes) and they seemed to be OK as long as the light was good but indoors they both sucked with AF If, like me you want the Sigma purely so you are not hitting high ISO's in low light then it's brilliant BUT focus in manual is safer!! To be honest I simply wouldn't trust AF in low light conditions. However it's an absolutely magic lens to use but watch out ...it will put close to 2lbs of weight in front of the camera if you are handholding ..it's heavier than it looks!!! Chris Chris |
Re: F1.4 E-mount?
Re: F1.4 E-mount?
There's the Mitakon 50/0.95 that is technically native e-mount, but it's MF.
No native AF f/1.4 lenses yet, but Sony has announced an e-mount Distagon 35/1.4. It'll be the first. (I think it has AF but I am not 100% sure.) |
