slomo over hd-sdi uncompressed? at DVinfo.net
Sony NXCAM NEX-FS700 CineAlta
Old June 24th, 2012, 07:18 AM   #1
Can someone confirm that if you capture the footage on an external device, that it will be send out before the avchd compression?
Cees van Kempen is offline   Reply With Quote
Old June 25th, 2012, 05:05 AM   #2
Re: slomo over hd-sdi uncompressed?
I believe that has already been anwsered in here:
http://www.dvinfo.net/forum/sony-nxc...g-fs700-2.html
Edit:
I see you already read it.
Logic says it's uncompressed.
If it could be compressed at 240fps, it could also be written to the memorycard without or with far less delay.
Brainstormnavigator searching for the hole in the sky.....
Audiovisual Designer (NL) - http://www.brokxmedia.nl
Walter Brokx is offline   Reply With Quote
Old June 27th, 2012, 12:57 PM   #3
Thanks Walter. I thought I read somewhere (donīt know where) that it is logical that the output is uncompressed, but that no tests to check this were done yet. hence the question.
