May 6th, 2013, 05:29 PM | #16 |
Re: Remote control of FS700 for slo-mo work
The plug on the FS700 is lanc-style -- not the EX1/3 lens controller style.
You should bring your extension cables when you go to do your camera checkout - just to make sure they work properly. A couple of other thoughts -- You should definitely have a monitor to verify camera output. It will also help you determine when you can roll again if doing multiple shots during a single fire event. Remember, when you trigger a slo-mo shot it sends its data to the buffer, then proceeds to write the data from the buffer to the SD card. THIS WRITING CAN TAKE A WHILE!!! It's not as though you can film a slo-mo clip at 240, wait a few seconds and then film another one. You will need to wait until the shot is written to card. This is where the monitor can come in handy, since you'll see the slo mo footage that is being written - so once the camera feed returns to regular speed you will be able to record again. Even a minute can be a long time to wait when there's a lot going on! |
May 6th, 2013, 06:37 PM | #17 |
Contributor
Thanks Dave. Yes, I've got a monitor to use as well. There should be at least 10 minutes between tests so I think I'll be okay. I've been looking at some of the slo-mo footage from the FS700 and find it quite impressive for the purposes of this shoot. It may not be a Phantom, but it's more than usable for my client.
July 24th, 2014, 09:37 PM | #18 | |
I just wanted to jump in here with a question about the LANC.? I've got a nice Lanc controller I use for my XhA1, and it works great, but I guess I'm concerned that I didn't see the lanc symbol in the specs of the FS700. I suppose that doesn't mean it won't control the 700, but I was just curious, and also wondered if the regular old lanc would work on the FS700 or does it require a newer lanc.?
July 25th, 2014, 08:12 AM | #19 |
I've experienced a burning smell issues running slow motion for over 3-4 hours. But I think it was the battery and not the camcorder.
July 25th, 2014, 10:45 AM | #20 |
Heard good reports on these. Used with an extension cable one of these might be ideal as they have a LED on them to indicate recording or not.
Pro-Lanc Chris Young CYV Productions Sydney |
